Old 09-25-2018, 02:35 PM
mfleming's Avatar
mfleming mfleming is offline
Question F-796A Fuel Tank Bracket Install
So I'm working to get to the point of fitting my -7 wings.
Previously I had fashioned and temporarily installed the F-796 tank attach shims and angles. The plans spell out doing the final drilling and bolting when the wing is fitted. BUT I see in different builders logs where the F-796A bracket is fitted beforehand.
Sooo...wait for the wing fit or knock this out now and do the final bracket bending when fitting the wing??
Michael Fleming
Joseph, OR
sagriver at icloud dot com
RV-7 Slider #74572
Started 11/2016
Donated and so should you
Old 09-25-2018, 08:00 PM
N908RV's Avatar
N908RV N908RV is offline
Default Drill it now
Michael, definitely recommend drilling that now while you have excellent access. You can always adjust the bend slightly on the bracket itself later after the wings were installed. Mine only needed a slight tweaking. Rob
Rob Brooks
EAA Tech Counselor
Warrenton, VA
RV-8, QB completed, flown 750hrs and sold
http://www.taildraggersinc.com/pages...RV_flying.html
RV-7, SB completed and flying Phase 2
http://www.mykitlog.com/N908rv/
Old 09-25-2018, 08:50 PM
mfleming's Avatar
Thanks Rob!
Michael Fleming
Joseph, OR
RV-7 Slider #74572
Started 11/2016
Old 09-26-2018, 08:30 PM
jcarne's Avatar
jcarne jcarne is offline
Yep I have heard the same thing from others so I went ahead and did mine before I flipped the canoe.
Jereme Carne
PPL
RV-7A Emp. done
Wings mostly done
Fuselage almost done
Finish kit arrived
Exempt but gladly paying!
