Old 09-25-2018, 12:38 PM
Eric B Eric B is offline
Default RV-12 iS E-LSA Certification and factory options
Probably been asked before, but!
When building to an E-LSA certification standard, the aircraft must be built like the factory model, yes? I'm guessing that an S-LSA is available with the same options that are available to builders. That means that no matter which factory options one could choose from, it can still be certified as an E-LSA, because the same is available from the factory?
Thanks!
There are only 10 kinds of people in the world, those who understand binary and those who don't.
Old 09-25-2018, 12:40 PM
Mel's Avatar
Mel Mel is offline
Yes, any mods approved by the kit manufacturer are acceptable.
A&P/EAA Tech Counselor/Flight Advisor/Nat'l Test Pilot School
<rvmel(at)icloud.com>
North Texas (8TA5)
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
Old 09-25-2018, 01:45 PM
Default Mods after certification
Having read numerous other posts, following certification as an E-LSA (with or without factory-approved mods), the E(xperimental) part kicks in, and non-kit supplier mods can be made, given that none of those take it out of the LSA Operating Limitations?
Old 09-25-2018, 02:16 PM
Mel's Avatar
Mel Mel is offline
Yes again. Once the aircraft is certificated in the Experimental category, one can make any changes so long as it does not remove the aircraft from the definition of LSA as stated in 1.1 of the FARs.
North Texas (8TA5)
FRIEND of the RV-1
Eagle's Nest Mentor
Old 09-25-2018, 02:39 PM
Thank you!
