Old 09-24-2018, 06:26 PM
Jetmec Jetmec is offline
Default RV9 wing dimensions
Iím in the process of cleaning out my basement and prepping it for my eventual build. Would like to know the exact dimension of the wings with/without control surfaces if anyone has them. Would like to limit non flying hangar rental as much as possible.
Old 09-24-2018, 06:47 PM
cajunwings cajunwings is offline
Default Wing dimensions
My wings are complete with control surfaces and wingtip installed. 12’ 3” from inboard edge of main spar to the outer edge of the installed tip. (Tip is 17” wide at trailing edge). Leading edge of wing to trailing edge of aileron is 53” and with wings in my rolling wing rack the trailing edge of the control surfaces is 63” off the floor. You could make wing storage as compact as possible by putting the wings on the floor nose down on padding and leaving the tips, control surfaces and maybe pitot mast off.
Don Broussard
RV9 Rebuild in Progress
57 Pacer
Old 09-24-2018, 06:50 PM
pilot2512 pilot2512 is offline
Happen to have mine on the table riveting the bottom skins...134x 44 inches
Jay
RV-9A
Empennage complete.
Wings complete.
Fuselage in progress
Wiring in progress
2018 Donation made!
Old 09-24-2018, 06:55 PM
Thanks for the replies. Would be pretty embarrassing to get those done and not be able to get them out of the house LOL. To bad Iím not closer to either of you. Would gladly come out and give you a hand on your builds.
Old 09-24-2018, 07:42 PM
Forgot to mention that is without the flap, aileron or tip.
Jay
RV-9A
Empennage complete.
Wings complete.
Wiring in progress
2018 Donation made!
Old 09-25-2018, 05:46 PM
Made a mock-up based off those dimensions and I could squeak them out my basement door or if need be I can go through interior stairs and out my living room. Appreciate the replies!
Old 09-28-2018, 11:30 AM
Sorry to bug you guys again. Do you know off hand how thick the wing is? Top to bottom skin. Thanks in advance
Old 09-28-2018, 11:45 AM
Iím 2000 mi away today. If you donít get an answer Iíll be back home tomorrow.
Jay
RV-9A
Empennage complete.
Wings complete.
Wiring in progress
2018 Donation made!
Old 09-28-2018, 04:05 PM
Vlad Vlad is online now
Here we go Sir.
