Go Back   VAF Forums > Main > RV Ongoing Maintenance Issues
Old 09-24-2018, 02:39 PM
rotoiti's Avatar
rotoiti rotoiti is offline
Default High oil consumption on an IO-540
My RV-10 has an old engine (about 5,000 hours on it). It was top overhauled before installing in the -10, and it had installed all new, nickel cylinders at that time.
The oil consumption was always high but during 4 years (and 300 hours) I owned the airplane, the consumption increased from 1 quart per 3.5 hours to 2 quarts per 3 hours. Oil analysis shows increased nickel but that is in line with nickel cylinders.
This is still in-spec by Lycoming standards (current consumption 0.66 qt/h vs. 0.87 qt/h maximum) and my mechanic recommends just adding oil. Looking for a second (or third or...) opinion
Thanks!
Llama (RV-10), flying. Currently down for engine overhaul.
Old 09-24-2018, 02:56 PM
William William is offline
Thatís a very high oil consumption rate. How many hours are on the cylinders?
Davis Aviation LLC (Owner)
RV aircraft builder/repair facility
Located (FD77) Wimauma, Florida
RV6A flying as of November 8, 2016. N717WK
Finishing a RV10
Old 09-24-2018, 03:06 PM
RONSIM's Avatar
RONSIM RONSIM is offline
Default High Oil Consumption, Until:
Our -10, ECI (new) Nickel cylinders had high oil consumption (qt every 4 hrs). We "broke in" with mineral oil and switched to Aeroshell after 50 hrs -- oil consumption remained high ----- THEN, we found out that ECI recommended Phillips XC for break-in and permanent use. We switched to the Phillips, and, over time, the oil consumption stabilized at quart every 10-12 hrs. Just a data point, but worked for us.
I use the Phillips on my new (at the time) ECIs on the -6A and certainly have no complaints.
Ron
RV-10 Co-built, maintained, flown (sold)
RV-8A Maintained and flown (Sold)
RV-6A Bought and Flying (N177RV), upgrades $$$
IO360, 180HP/CS, AFS 5600T, D10A, G650, G430, G327, ADS-B, VIZ385 AP
Very Happy Contributor
Comm, SMEL, CFII, A&P
Based at KCLW (Clearwater, FL)
Old 09-24-2018, 03:17 PM
rotoiti's Avatar
385 hours on the cylinders, since 2012 I believe.
Old 09-24-2018, 05:42 PM
grubbat's Avatar
grubbat grubbat is offline
Default Break-in
If the cylinders weren’t broken in properly, they may never break in no matter how much time they have on them. Assuming valves are good, pull them, crosshatch the cyl, install new rings, then break in properly.
Good luck !!
Craig
RV-3 Sold
RV-4 Sold
RV-6a Sold
RV-9 IO-360 CS, Built and Flying
Comanche 260 - poor mans RV-10
Old 09-24-2018, 08:23 PM
With that high of a oil burn with such low hours on your cylinders I would definitely be pulling the cylinders for inspection. What do your spark plugs look like? How about the inside of your exhaust pipes?
Bill
Finishing a RV10
Old 09-25-2018, 12:55 PM
rotoiti's Avatar
Yes, I have no idea if the cylinders were broken in properly. I bought this airplane when it had 106 hours on it.
Spark plugs look fine, no fouling. I have dual LSE Plasma 3. My mechanic insists on aviation plugs, so that's what is installed there now. Not sure if that could be the reason.
Compression is fine, two cylinders are in 69-70 range, rest is 75-77.
Old 09-25-2018, 04:05 PM
RV8iator's Avatar
RV8iator RV8iator is offline
I’d get a second opinion on mechanics.
Jerry "Widget" Morris
RV 8, N8JL, 2700+ hours
VAF #818
Saint Simons Island, GA. KSSI
PIF 2008, 2009, 2010, 2011,2012, 2013, 2014, 2015, 2016, 2017, 2018.
I just wish I could afford to live the way I do
Old 09-25-2018, 04:25 PM
Carl Froehlich's Avatar
+1 on Jerry’s comment. While I agree this has nothing to do with your excessive oil burn, use the recommended plug. If your mechanic does not understand electronic ignitions, don’t let him work them.
Just to make sure - I assume you are not filling up the sump to 12 qts. Most people run around 8 or 9 qts. Anymore will just blow out the crankcase vent.
Old 09-25-2018, 10:26 PM
edsong's Avatar
edsong edsong is offline
Default Oil consumption
Carl is right. Us guys that have 4 cyl engines run 6 quarts max.
Eddy
Edson Grindeland
Hatton, ND
RV-8 Flying
http://www.hattonflyingcircus.com
You do not need a parachute to skydive. You only need a parachute to skydive twice.
