Old 09-23-2018, 08:19 AM
Pman Pman is offline
Default RV8 SikaFlex Question
For those RV8 Builders who have used SikaFlex to attach your canopy:
Question, reviewing the plans (DWG44 Section A-A) this shows the plexiglass cut "even" with the bottom of the canopy frame. For those who have used Sika, did you cut your canopy plexiglass per the plans (even with the bottom of the frame), OR did you cut your glass a little lower "below" the bottom of the frame to allow the Sika to have more surface area to support/hold?
I've cut my canopy per the plans, (it is even with the bottom of the frame),
I'm second guessing myself and wondering, should I have cut the plexiglass lower (below the frame) so as to allow more area for symmetrical Sika filets on the upper and lower surfaces of the canopy frame?
Thank you in advance for sharing your experience and insight to my questions!
Mike Perillo
Old 09-23-2018, 11:32 AM
ColoRv's Avatar
ColoRv ColoRv is offline
I cut per plan. No issues after 4 years and I frequently travel cross country at 17,500. With all the talk Iíve seen of RV8 canopies popping in cold I am very happy mine has no rivets, screws or otherwise pokey bits of canopy splitting metal in it.
Build on.
RV-8 Flying
1,235th flying RV8
SARL Race#95
SnF Homebuilt Judge
2015 Sun n Fun Kit Built Reserve Grand Champion
2015 Oshkosh Kit Built Champion
2015 Jeffco Kit Built Grand Champion
2014 Oshkosh Outstanding Workmanship Award
Broken Warrior of the Jarhead Clan
Old 09-23-2018, 01:21 PM
Carlos151's Avatar
Carlos151 Carlos151 is offline
Default Cut even
Bottom of my canopy was cut even with the bottom of the frame. No issues after 3+ years.
Karl Richcreek
RV-8
N151TK "La Otra Chica"
Flying as of August 14, 2015
Old 09-23-2018, 02:57 PM
SgtZim SgtZim is offline
I don't think you'll need to worry at all. Sika seems very strong and you'll have the canopy skirts over the bottom of the canopy helping hold on. I did the full treatment on the outside of the glass and the inside of the skirt where they contact - cleaner, primer, and sika.
RV-8 slow build
IO360-M1B Sensenich fixed pitch
Garmin G3X
GTN 625
GNC 255
GTR 20
GTX 45R
G5 x 2
Facebook "log" https://www.facebook.com/BZsRVproject/
Old 09-24-2018, 03:51 AM
mike newall's Avatar
+1 That's how we did ours.
Donated in 2018
Old 09-24-2018, 05:55 AM
steve murray's Avatar
steve murray steve murray is offline
My canopy was cut per plans. 750 hours and ten years later, no issues.
Steve
RV8 Flying since 2007
RV10 in construction (Finish Kit)
