Old 09-22-2018, 02:40 AM
Default Mounting Dynon Skyview GPS-2020 Antenna
Has anyone noticed an interference with the GPS-2020 antenna wires passing through the F-1201Z retaining plate?
There is a large hole in the retaining plate but it is extremely off-center with respect to the wires protruding from the bottom of the Skyview GPS-2020 antenna. The wires actually interfere with the edge of the clearance hole and the aluminum plate can easily cut through the wire insulation.
Hinckley, Ohio (1OA2)
EAA #499867
RV-12 Bought Flying Oct 2015 with 48TT - Hobbs now 419
LSRM-A Certificate 2016
Special Thanks... EJ Trucks - Crew Chief A-4 Skyhawks
and MJ Stricker (my flight instructor) - 1st Lt./Captain B-17H WWII
Old 09-22-2018, 04:19 AM
Jamesey Jamesey is offline
Default Cut a slot
Agreed. Just file out a small arc to make clearance. Thatís what I did.
Old 09-22-2018, 06:25 AM
pilotyoung pilotyoung is offline
Default GPS 2020
I made the hole larger to give the wires clearance.
Old 09-22-2018, 07:44 AM
I thought maybe I just had the problem. I sent an email to Van's Tech Support detailing the wire interference. Maybe Van's will issue a SB so folks make sure they address this before problems occur in the field.
EAA #499867
Old 09-22-2018, 08:26 AM
benfra benfra is offline
Default Enlarged hole
I just enlarged hole, be sure to clean and de burr. Good luck!
Old 09-22-2018, 11:37 PM
dbhill916 dbhill916 is offline
Ditto to the other responders. I found the hole to be off center/too small for the 2020, so I just used a Dremel tool to remove sufficient offending material to allow easy passage for the wiring bundle.
Don't forget to UPDATE YOUR SYSTEM to tell it that it's got a 2020 installed! I spent way too much time & money debugging a "bad" 2020 that was merely my fault for not following instructions.
David B. Hill
N76012
RV-12 #0760
http://n76012.blogspot.com
Dues paid through 6-2019
Old 09-23-2018, 09:52 PM
bruceh's Avatar
bruceh bruceh is offline
When I first installed the Dynon GPS-250, the wires that exited the unit were off center, so that's where I made the hole in the doubler. This last year, I upgraded to the GPS-2020 and lo and behold the wires are now centered. I did as others here suggested and just enlarged the hole in the doubler to make it centered for the new wiring exit. It was just about 1/4 to 3/8" off from the original unit. Makes me think that Dynon is the culprit here in moving the wiring on their units and Van's designed to the original offset hole.
Bruce Hill
RV-9A N5771H flown over 600 hours!
2018 VAF donator
EAA Tech Counselor
Old 09-23-2018, 10:04 PM
az_gila's Avatar
az_gila az_gila is offline
Question
According to the Dynon documentation the old (250) and new (2020) units are identical and both have a small offset.
1.75 inches between mounting holes and the wires are 1 inch from set of holes.
Perhaps rotating the unit 180 degrees might help? The antenna does not have a mounting direction requirement.
Note, rotating the unit would move the position of the wires exactly 1/4 inch per your posting.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 09-24-2018, 01:03 AM
What prompted me to start this threadÖ a friendís RV-12 built by Synergy in Eugene, OR developed an intermittent GPS fault on Dynon dual screen HDX displays. Dynon was contacted because units are still in first year of warranty. Dynon theorized bad GPS antenna and sent a new replacement. When we changed out the antenna we noticed wire cut-through at the F-1201Z Retaining Plate. Synergy didnít add clearance and just mounted the antenna with wires forced against sharp metal edge. At 80 flying hours a big red X was displayed on both EFIS screens, which was a little disheartening to say the least.
A big thank you to Dynon for stepping up to the plate, but real problem is poor build quality at Synergy. Iím sure Dynon will re-coop their cost now that we have full discloser. I suggest all owners of Synergy built aircraft should look for this assembly fault.
EAA #499867
