Old 09-21-2018, 02:50 PM
pilotyoung pilotyoung is offline
Default Earthx Battery
Has anyone done the weight & balance calculations when replacing an Oddsey battery with an EarthX battery? If will you share your work?
Thanks.
John D. Young
Old 09-21-2018, 05:12 PM
Scott Hersha Scott Hersha is offline
You can do that yourself knowing the weights of the two batteries in question and itís mounted CG position relative to datum. If mounted in the same place, your empty CG will move aft slightly if mounted forward, and the opposite if mounted in the back. Youíll be able to carry about an extra 2 gallons of gas at the same gross weight with the EarthX.
SH
RV6/2001 built/sold 2005
RV8 Fastback/2008 built/sold 2015
RV4/bought 2016/sold/2017
RV8/2018 built/Flying
Cincinnati, OH/KHAO
JAN2019
