Old 09-21-2018, 12:20 PM
Harley_Pilot Harley_Pilot is offline
Default Elevator close out riveting
Iím working on an RV-14 empennage kit and step 2 of the left elevator inboard close-out on page 09-21 says to rivet the E-921 Gusset to the E-00907-1L Rear Spar with AN470AD4-4 rivets. I was able to secure the lower rivet, but the upper rivet is blocked by a knuckle of the trim tab hinge. I canít lift the
E-00901A Skin high enough to rivet from the back side. Iíve looked at using a pulled rivet but again I donít have access straight at the rivet. Iíve tried to go at it offset a bit, but the pulled rivet wonít seat against the Rear Spar. I donít have a way to drill it out if I make a mistake so Iím a bit reluctant to literally & figuratively pull the trigger. Any suggestions?
John House
Started RV-14A 01-Sept-16
Restarted August 2018
Dues Paid 2019
Granite Bay, CA
Old 09-21-2018, 04:10 PM
Reflex Reflex is offline
A picture is worth a thousand words.
One thing I've learned is not to be afraid to modify tools. I know it's hard to take a perfectly good tool and grind it up....but to me the finish of the aircraft is much more important than the finish of the tool
Dues Paid for 2019
RV-14
Empennage Complete
Getting Ready to Close Wings
Old 09-21-2018, 05:08 PM
Great idea. I just took a grinder to my rivet set and it worked like a charm.
Thanks!
John House
Dues Paid 2019
Granite Bay, CA
