Old 09-19-2018, 05:41 PM
Bavafa Bavafa is offline
Originally Posted by Stockmanreef View Post
Drift is fine for this thread.
Awesome and thanks for the flexibility and info from E.
The wing bolts of my 7A was pain in the rear but it has much less room to deal with.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 09-19-2018, 05:46 PM
RVTrumpet's Avatar
RVTrumpet RVTrumpet is offline
Originally Posted by RV-14E View Post
Just for future reference, the torque seal should really go between the structure and the nut (across the washer in this case) instead of between the bolt threads and nut.
A couple RV-12s
Building 8A
NOTE: The information, ideas, and opinions presented in this post are my own and not those of my employer. Build, test, and fly at your own risk.
Old 09-19-2018, 05:57 PM
RV-14E's Avatar
RV-14E RV-14E is offline
Thank you. I hadn't considered that. I investigated your suggestion and found this EAA video that offers the same advice:
https://video.eaa.org/detail/video/2...al-application
E
http://rv-14a.blogspot.com/
Old 09-19-2018, 05:59 PM
StressedOut StressedOut is offline
I put torque seal on the threads, the nut and the structure. Maybe that's just overkill.
Edit: After reviewing the video, I will not be putting torque seal on the nuts.
Art Jackson
RV-14A Kit#140433, N393AJ Reserved
Completed: Vertical Stab/Horizontal Stab
Scrapped: Rudder
Working on: Empennage (Elevator)
Construction log - mykitlog.com/ajackson
Dues paid on 10 October 2018
Member of EAA Chapter 92 (KCNO)
Pet peeve: "Lose" (rhymes with "booze") is the opposite of "find". "Loose" (rhymes with "juice") means "not tight".
Old 09-19-2018, 06:14 PM
RV-14E's Avatar
Originally Posted by StressedOut View Post
I put torque seal on the threads, the nut and the structure. Maybe that just overkill.
Check the EAA video above. It's only 2 minutes. The presenter shared that when the seal is on the threads, removing the nut can cause the threads to "roll" (I think he means "strip"), requiring cutting of bolt for removal.
E
