Old 09-15-2018, 05:53 PM
DaveO DaveO is offline
Default AP install in the 14
I have ordered the QB wing kit and I wanted to install the brackets that hold the servos in the Tail cone and later in the wing.
I ordered the AP servo install from Van's and I was disappointed to learn that most of the hardware does not come with this kit.
Basically I got wiring and bolts all for a 118.00. A little expensive i think.
Does anyone know when I will receive the mounting brackets? Is it with the Finish kit? If it is with the finish kit, then why send them in that manner as the owner might not be installing a AP. Then it is a waste of $$.
If they are somewhere else where would I look? What am I missing?
When i built my 7A the mounting kit was ordered from Dynon. I did not see that option now.
Thanks for your response.
RV-7A N1243A Sold
#140479 RV-14A N1479B Reserved
Old 09-15-2018, 06:38 PM
mturnerb mturnerb is offline
The roll servo mount is included with the wing kit. The pitch servo mount is part of the elevator bellcrank assembly included in the fuselage kit.
The only extra mounts I had to buy were for the (optional) yaw servo - bracket from Van's and "bow" from Steinair - I'm using Garmin so not sure how this works for Dynon servos.
Turner Billingsley
RV-14A In Progress
N14VB Reserved
Old 09-16-2018, 06:53 AM
kbalch's Avatar
kbalch kbalch is offline
Originally Posted by mturnerb View Post
The roll servo mount is included with the wing kit. The pitch servo mount is part of the aileron bellcrank assembly included in the fuselage kit.
That's the elevator bellcrank assembly, correct? Any reason not to install the pitch and yaw servos relatively early in the fuselage assembly process (certainly prior to joining the tailcone) while access to the bellcrank area is unobstructed?
Ken
RV-8 N118KB (sold)
RV-14A #140494 (Finish kit in progress)
N114KB (reserved)
Old 09-16-2018, 07:04 AM
JDA_BTR JDA_BTR is offline
There is every reason to do it early. Doing it later is a pain and I wish they just put those parts in the tail kit because the tiny expense is irrelevant to the hassle.
Ser 104142, RV-14A
N1463
Ready to gas it up!
Urologist, AME
Old 09-16-2018, 01:39 PM
CORRECT - my mistake - editing original post.
Turner Billingsley
RV-14A In Progress
N14VB Reserved
Old 09-17-2018, 08:14 AM
I installed pitch and yaw servos after the empennage/fuselage join - not really too hard. You have to install a bracket for the yaw servo which would have been easier before the join - I ended up changing rivets to screws where the yaw servo bracket attaches to the bulkhead (I messed up one rivet hole and after thinking about it decided it would be nice to have the bracket easily removable). What was harder was installing the cable clamps on the yaw servos (part of Van's yaw servo installation kit). I waited to do this until there was a convenient time to mount the tailfeathers - rudder has to be centered and rudder cables tight to do this. I had to crawl a bit farther back into the fuse to tighten/position the clamps. So if you have all the parts and particularly if you're opting for yaw servo, do it before the join.
Turner Billingsley
RV-14A In Progress
N14VB Reserved
Old 09-17-2018, 05:12 PM
Does Dynon Skyview integrate a Yaw servo in the mix with roll and pitch?
In my 7A build I do not think they did, but years later they might.
I had not planned on using the Yaw servo, but rethinking.
RV-7A N1243A Sold
Old 02-26-2019, 05:16 AM
mjanduda's Avatar
mjanduda mjanduda is offline
So just install the yaw servo before the join or is it a good idea to not rivet some tailcone skins until you install the servo?
I'm about to assemble the tailcone and am wondering if I should wait to rivet the skins until I have decided with which servos I'll go.
Malte
Old 02-26-2019, 07:56 AM
Malte
Before the join. I would do it with rudder and rudder cables in place so you can position the clamps. I think if you did it with tailcone skins off the structure might twist a bit.
Turner Billingsley
RV-14A In Progress
N14VB Reserved
Old 02-26-2019, 07:57 AM
bkervaski's Avatar
Also if you haven't done the SB now is a good time ...
Progress: Flying!
