Old 09-14-2018, 09:27 AM
azflyer21 azflyer21 is offline
Default QB Wing Question
I have received my QB wings, what a great decision.
Should I remove the fuel tanks to finish the wings?
Kevin Lippert
Zenith 750 completed 2016 -
Sold
N1402 reserved
RV-14a Empennage Done
QB Wing QB Fuse inprogress
Build Log
Old 09-14-2018, 09:39 AM
mjanduda's Avatar
mjanduda mjanduda is offline
Hi Kevin,
how long did it take from order to delivery?
Malte
Old 09-14-2018, 10:17 AM
bkervaski's Avatar
Nope, but make 100% sure the QB guys torqued all the bolts to spec.
Progress: Flying!
Old 09-14-2018, 03:53 PM
Originally Posted by mjanduda View Post
Hi Kevin,
Malte
Malte,
Here is a timeline of the quickbuild order-delivery time frame for the U.S.
Ordered QB Fuse & Wings 12-18-2017
Van's Rec'd kits 06-25-2018
Paid final to Van's 06-27-2018
Delivered 09-02-2018
PM me about the delay in delivery. I used a preferred vendor that does not crate the kits and this created a substantial delay. I know this does not affect you in your location.
Kevin Lippert
Sold
N1402 reserved
Build Log
Old 09-14-2018, 04:24 PM
Default Tanks
I opted for the ER tanks. As such, I ended up removing mine from the QB wings. It wasn’t required but it made things easier. Especially leak checking the tanks. I found the B nuts on my vent lines were NOT tight. I made a stubby wrench to fish in through the fuel level sender hole to tighten them. It wasn’t difficult to remove the tanks...
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
290 HP Barrett Hung
Wiring...
Dues Paid 2018,...Thanks DR+
Old 09-14-2018, 04:41 PM
Discus2b Discus2b is offline
Originally Posted by azflyer21 View Post
Malte,
Oshkosh got in the way no doubt. Preferred vendor is very busy July/Aug and extra time should be planned during this time. This vender handles the transfers of aircraft and pieces to/from Osh for Vans.
H
Old 09-14-2018, 04:55 PM
mjanduda's Avatar
Thanks for the timeline!
I think even six months from ordering until the kit is at van's is quite a lot. Probably I'll go with slow build wings and a qb fuselage.
Malte
Old 09-14-2018, 05:35 PM
mturnerb mturnerb is offline
I found it easier to install the fittings and the fuel sender as well as testing the tank with them off the wing (built a cradle to hold them on bench). I replaced all the bolts with new and torqued them myself - some of the ones I removed were over-torqued.
https://turnerb14a.blogspot.com/2018...left-wing.html
Turner Billingsley
RV-14A In Progress
N14VB Reserved
Old 09-15-2018, 03:17 AM
TASEsq TASEsq is offline
Originally Posted by mturnerb View Post
Turner - GREAT idea using the centre punch dots to mark your parts L/R and their alignment. I have tried many things - like marking with a sharpie (acid etch took it off), wires / tags (time consuming and acid took the pen off the tags anyway!), keeping track of them (way too easy to forget or mix it up), so I finally went ahead and purchased a little vibrating pencil - figuring I would just make a little mark somewhere on the part for L/R or alignment etc - but this idea is even simpler. Thank you!
___________
Trent Stewart
Melbourne, Australia
http://www.tasrv14.blogspot.com.au/
Dues paid until April 2019
Old 09-15-2018, 09:11 AM
Thanks for the feedback - this is a great community for sharing and I'm happy that I can contribute!
Turner Billingsley
RV-14A In Progress
N14VB Reserved
