Old 09-24-2018, 06:59 AM
Rich---email me and I'll give you some ideas.
Tom
Ridgeland, SC
Old 10-02-2018, 04:57 AM
AirHound AirHound is offline
Default Fuel return fitting tiny hole.
Tom
Tom, I installed your fuel line system last year and enjoy its strengths! Do you offer the fuel return fitting with larger orifice? Iím experiencing spiking fuel pressure indications in the dynon/green-yellow band with aux on and off in various phases of operation. Could this cause a slightly rich fuel mixture?
Thank you!
Doug
Doug
Old 10-02-2018, 01:07 PM
HI Doug. right now we dont, BUT the good part of our fitting is that you may drill the orifice to a slightly larger size if you wish.
Tom
Ridgeland, SC
Old 10-02-2018, 07:02 PM
Tom
Tom, thank you for that ultra thin bit. Will it fit in an electric hand drill? I donít have a press. I guess I could go to a machine shop. From which end do I drill?
Doug
Old 10-03-2018, 02:14 PM
Aircraft Specialty Aircraft Specialty is offline
Doug....
Good afternoon. You need an air drill to drill it out as the drill bit is really tiny.
I drilled one out for you today and if you send me an email I will send you the new restrictor with a larger hole. The new restrictor fitting is drilled out to .020-.021 which is slightly larger than the .015 that is specified in the Rotax manual. However, it matches the orifice size that is actually being shipped by Rotax. Their manual and actual restrictor orifice sizes differ. We have tested both orifice sizes and have noticed no appreciable difference between them.
Have a great week and take care,
Steve
Steve Tschurwald- Aircraft Specialty LLC (Your source for Custom Parts for Experimental Aircraft), AS FLIGHTLINES (Joint Venture with TS Flightlines)
aircraftspecialty@gmail.com
www.aircraftspecialty.com
Old 10-05-2018, 04:59 AM
Thank you! Iím looking forward to reporting out on any effects.
Doug
Old 01-06-2019, 02:27 PM
We have had a number of inquiries on this package in the last few days.
I wanted to make sure that everyone has seen the Rotax fuel/oil hose guide which helps builders/owners determine what kind of hoses they currently have on their engines and whether or not they are nearing "scheduled" replacement.
http://aircraftspecialty.com/PDF%20D...se%20Guide.pdf
Please feel free to contact us if you have any questions at all regarding these kits.
We currently have one of the Fuel hose kits left in stock and will be building several more next week. We try to keep stock on a few of them, but ask for about a 1 week notice prior to shipment to ensure that we don't make anyone wait.
Thanks again to everyone and have a great week
Steve
