Go Back   VAF Forums > Model Specific > RV-4
Old 09-13-2018, 04:10 AM
chris mitchell chris mitchell is offline
Default Location for air-oil seperator in RV-4
I have a Raven air-oil seperator tank that I'm rying to find a good spot for. Currently I have it attached to the outside of the engine mount, just behind the engine. Unfortunately I cannot get it low enough to get the cowling on and still have the bottom of the tank above sump level - the fitting on top that takes oil from the breather pokes up quite a long way. Space is limited and tight - my next port of call would have to be the firewall, on the right side and as far over as possible, but I think there will then be interference between the 45* elbow on the bottom of the tank and the top of the rudder pedal forward extension.
Any good ideas or even better some photos would be really helpful.
I fly "gentleman's" aerobatics with some zero G or short periods of -ve G, and wanted to avoid having to clean the belly, but without the weight and fuss of a full inverted system - which must be even more difficult to avoid.
Chris
Chris Mitchell
Repeat offender;
RV-8, QB, built, flown 150 hours, sold;
RV-4 - attempted repair, rebuild and remediation - abandoned and junked ;
RV-4 fuselage and wing kits - both at QB stage;
2015-2018 dues paid!
Old 09-13-2018, 09:29 AM
acam37's Avatar
acam37 acam37 is offline
Default My Location
Not much room, but this is the only place I had left to mount mine.
Arlie Conner
RV-4 (N124TT) Sold
RV-8 (N269CP) Sold
RV-4 (N684ML) completed 3-17-19
KOCH Nacogdoches
Old 09-13-2018, 10:33 AM
f14av8r's Avatar
f14av8r f14av8r is offline
Default Here's how I did mine
Randy King
Tampa (Wimauma), Florida
RV-4 N212CS (sold)
RV-8 N184RK (flying)
Flying an A320 to pay the bills
Exempt and gladly donating anyway - Current through March 2020
Old 09-15-2018, 02:11 AM
Thanks guys - which tank are you using BTW? Raven or some other?
Chris
Chris Mitchell
Repeat offender;
Old 09-15-2018, 05:25 AM
f14av8r's Avatar
Default Standard Raven
Mine is the 4" Raven tank.
Randy King
RV-4 N212CS (sold)
Old 09-15-2018, 02:22 PM
acam37's Avatar
Mine is a Raven
Arlie Conner
RV-4 (N124TT) Sold
RV-8 (N269CP) Sold
KOCH Nacogdoches
Old 09-16-2018, 06:33 AM
flyboyedwards flyboyedwards is offline
Default Inverted oil system location
Iím dealing with the same issue! Thanks for posting!
Old 09-19-2018, 01:31 AM
Default Manged to get it done
So the answer is pretty obvious really, thanks for the pictures and tank type, which confimred it could be done.
So - mine is mounted on the engine mount using adel clamps one of which needed a couple of spacers before bolting the clamp to the tank mount. Get the tank down so that the top is just level with the top of the mount. Positon the inlet elbow (tube coming from the engine breather) towards the front/inside edge. Hey presto, the cowling fits.
Now - mine is on the right side as I wanted to put my oil cooler on the left. However, Randy - your tank I surmise is on the left side, which must give a much better run for the pipe between the engine breather and the tank inlet - so where have you put your oil cooler? On the firewall or somewhere more cunning?
Chris
Chris Mitchell
Repeat offender;
Old 09-19-2018, 08:44 AM
f14av8r's Avatar
Default Oil Cooler
Hi Chris,
The Oil Cooler in the RV-4 is on the right side firewall. The left side location of the tank is ideal as it is very close to the breather outlet. With my RV-8 I had to put the tank on the other side though because the oil cooler takes up the right side space on that airplane.
Randy
Randy King
RV-4 N212CS (sold)
