Old 09-15-2018, 10:06 AM
You can also put a drop of weld on the worn spot and file it to the correct profile. A chain saw file works well for this.
CPL & IFR rated
EVO F1 Rocket 1000 hours,
RV14 Tail dragger
Fairlea Field
fairleafield@gmail.com
Old 09-15-2018, 05:27 PM
snoop9erdog snoop9erdog is offline
Default The 9
I have the rod link to install......but as someone who is a newby tailwheel pilot, should I put the chains on and get experience before tackling the steering link?
Or is it better to start off right off the bat with the link. For those of you 9 drivers.....what do you have? Are the chains more forgiving?
Ed Avila
St. Johns, AZ (SJN)
N646A RV9
Worlds longest RV build...but getting there
Old 09-15-2018, 08:31 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
I have always just had the chains on my -9 and happily donít know what Iím missing.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2020
Old 09-15-2018, 09:40 PM
SHIPCHIEF SHIPCHIEF is offline
Well Then!
Thank You, Terry, Vince and Tom.
I just upgraded to the steering link + Tie Down Ring, I think it's a big improvement in steering stability on my RV-8. Slowing down thru 50 MPH is more stable, and I just like it better.
I can't imagine the steering link making tail wheel transition harder?
I always kept slack in the chains w/ springs to prevent ground loops when one side breaks off. I like Dan's cable upgrade too.
The tie down ring has been worth the price of admission.
Scott Emery
http://gallery.eaa326.org/v/members/semery/
EAA 668340, chapter 326 & IAC chapter 67
RV-8 N89SE first flight 12/26/2013
Yak55M, and the wife has an RV-4
There is nothing-absolute nothing-half so much worth doing as simply messing around with Aeroplanes
(with apologies to Ratty)
2019
Old 10-19-2018, 10:04 AM
trackdom trackdom is offline
Default Broken tailwheel link
Hi,
At about 180 hours, my RV8 tailwheel link broke when landing. I ordered a new one from JD Airparts . I am wondering if I could fly safely without any link? Taxiing is not a major issue, but in flight I am not sure of the rudder stability...
Thanks for your opinions
rv8
First flight february 11 th 2016 , delightfull....
Old 10-19-2018, 10:10 AM
Sam Buchanan's Avatar
been here awhile
Originally Posted by trackdom View Post
Hi,
One of the rod end bearings on my Rocket link (RV-6) broke while taxiing out of a Saturday breakfast. The steering was a bit looser but landing back home was a non-event. There was no effect on in-flight stability.
Sam Buchanan
1999 RV-6
1918 Fokker D.VII replica
Old 10-21-2018, 01:30 AM
Thank Sam for the info. Anyway I was able to repair the link . But regarding flight controls I am always very carefull. Thatís A good info when you donít want to be stuck far from your homebase.
rv8
Old 10-22-2018, 08:55 PM
Tom @ N269CP Tom @ N269CP is offline
My RV-8 had a rocket link already installed when I bought it. I prefer the positive steering control with the link over the tap-dance-inducing hysteresis of chains/springs. Steering with the link is like coasting on a bike....no wasted pedal/steering motion.
I found no problem whatsoever using the link...it was an unexpected and welcome improvement over other taildraggers I've flown. It made landings that much easier.
Chains/springs are like steering a bicycle with a loose handlebar.
Kind regards,
Tom
Machinery Engineer
RV-8 N269CP
O-360-A1A w/Hartzell CS prop on 100LL
Slick-IC+PMag ignitions
Steam gauges, EI UBG-16 & FP-5, Garmin Aera 660
TruTrak autopilot (GPS coupled)
Infinity grip w/Matronics trim speed control
Reiff engine preheater
AntiSplat oil mist separator
MH O2 system
Old 10-23-2018, 12:52 PM
smokyray's Avatar
smokyray smokyray is offline
Default Chain Chain Chain...
Originally Posted by DougCronkhite View Post
My 8 currently has chains on it.. but the previous owner purchased the RV Rocket steering link and tie-down control arm but never installed it? Any recommendation on either?
Doug,
I suppose I am from the RV "Bush-plane Wannabe" side of total performance with 80+% of my landings are off pavement.
My RV4 (and RV6"X") had chains initially back in the 90's but now has "the fix". The fix came after the Rocket Steering link on my HR2 broke off on my first landing at my home turf strip in FL.
The fix?
These: https://www.vansaircraft.com/cgi-bin...duct=tail-lynx
Not cheap, but they withstand off road abuse and work nicely with the API, FlyBoy or Bell Tailwheel.
V/R
Smokey
Old 10-23-2018, 01:44 PM
scsmith scsmith is offline
Default Beware of asymmetry in castor release point
Bruce Eicher linked to the thread I posted where I found out the hard way (although not as hard as it could have been) that with the rocket link, there is an asymmetry in the geometry that causes the wheel to get to the castor release point with less than full rudder in one direction.
Jliltd -- what you describe is exactly the issue. Paul, it is not a wear issue, it is intrinsic to the asymmetrical geometry because the angle from the rudder hinge axis to the point on the rudder horn that drives the link is different than the angle from the attach point on the steering arm to the tailwheel pivot.
As some have noted, it is not too difficult to manage a taildragger with a full castering tail wheel, and I have done that a lot. But what is hard is to have the steering lock let go on you abruptly.
A change in the design of the steering arm so that the angle matches the angle on the rudder horn would prevent this. Would be easy to do if the supplier would step up and just do that.
Until then, I went back to the Tail Lynx, which is a very tidy spring system.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 550
also LS-6-15/18 sailplane
VAF donation Jan 2019
