Old 09-12-2018, 03:14 PM
Robert M's Avatar
Robert M Robert M is offline
Default Wheelpant tire opening
I cant find a reference to a specific dimension for the opening of the wheel pant tire opening, any suggestions?
Robert
"Pilots: Looking down on people since 1903"
(author unknown)
RV-9, N556RM, O-320, Dual PMags, Catto 3 blade.
Phase 1 completeded - FLYING Phase 2
Mosquito XEL kit in garage being built.
Old 09-12-2018, 03:33 PM
Default Decide
Decide if you will be using new or recap tires. I went with recaps as my experience with flight school aircraft is that the recaps last quite a bit longer than the new tires. The recaps are slightly larger, so if you cut you pants to fit the recaps, you can always use new. The converse is NOT true. If you cut the pants for a new tire, the recaps will be too tight. I used about a 5/8 gap around the tire to layout the pant cutout...
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
290 HP Barrett Hung
Wiring...
Dues Paid 2018,...Thanks DR+
Old 09-12-2018, 04:09 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Originally Posted by Robert M View Post
I can’t find a reference to a specific dimension for the opening of the wheel pant tire opening, any suggestions?
Robert
My rule of thumb is to use my thumb - the first joint should be able to fit between the tire and teh wheel pant all the way around.....
FWIW, I wear a large sized glove - pretty normal size hand/thumb
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 09-12-2018, 05:25 PM
Scott Hersha Scott Hersha is offline
I used my middle finger......... but I have arthritis, so probably about the same size as PDs thumb.
SH
RV6/2001 built/sold 2005
RV8 Fastback/2008 built/sold 2015
RV4/bought 2016/sold/2017
RV8/2018 built/Flying
Cincinnati, OH/KHAO
JAN2019
Old 09-12-2018, 07:49 PM
bruceh's Avatar
bruceh bruceh is offline
I had to trim more when I changed tires from Van's original Aero Classics to Desser's Monster retreads. A lot more.
If I ever go back to Aero Classic sized tires, I'll be able to get more than one finger/thumb in there. Definitely give yourself more room if you are planning on painting.
Bruce Hill
RV-9A N5771H flown over 600 hours!
2018 VAF donator
EAA Tech Counselor
Old 09-12-2018, 08:20 PM
airguy's Avatar
airguy airguy is offline
If in doubt about where to trim, just do about 20 or so landings and pull the fairings - then trim 1/4" beyond all the torn up fiberglass - and that will be just about right.
Greg Niehues - PPSEL, IFR, Repairman Cert.
Garden City, TX VAF 2019 dues paid
N16GN flying 380hrs and counting! Built an off-plan 9A with too much fuel and too much HP. Should drop dead any minute now.
