Old 09-09-2018, 08:18 AM
OrenAir OrenAir is offline
Default No room for the countersink cage
I'm supposed to countersink #30 the rudder stops, although there's no way the cage can fit inside that angle. How do you do this step?
Old 09-09-2018, 08:21 AM
Mel's Avatar
Mel Mel is offline
Most people obtain a second cage and cut away one side.
Another option is to remove the cage and carefully "freehand" the countersink.
A&P/EAA (LifeTime) Tech Counselor/Flight Advisor/Nat'l Test Pilot School
<rvmel(at)icloud.com>
North Texas (8TA5)
RV-6 Flying since 1993, 172hp O-320, 3-Blade Catto (since 2003)Sold
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
Old 09-09-2018, 08:45 AM
coffeeguy coffeeguy is offline
Everyone has that problem. You have decide what is right for you. I think I wound up taking the CS bit and putting it on my deburring tool and hand cranking that. Not show quality, but certainly acceptable. Those rivets were a little difficult to set too, can't get the head of your flush mount rivet set in there. I wound up using a flat piece of steel and using that between the rivet and the flush mount rivet set.
Jeff Dingbaum
RV-14A empennage, wings
Cherokee 180
2019 dues paid
Old 09-09-2018, 08:48 AM
azflyer21 azflyer21 is offline
I used my hand deburring tool for these. You will find other areas where this tool will work nicely for the countersink.
Kevin Lippert
Zenith 750 completed 2016 -
Sold
N1402 reserved
RV-14a Empennage Done
QB Wing QB Fuse inprogress
Build Log
Old 09-10-2018, 07:00 PM
Stockmanreef Stockmanreef is offline
+1 to hand deburring
Ken Stockman
Midland, MI
EAA Chapter 1093 member
RV-14a (serial number 140073)
N73XP (at least that # reserved now)
Old 09-11-2018, 06:53 AM
bkervaski's Avatar
+2 to hand deburring tool ... once I got some practice I found myself going for this tool vs the drill and cage as it was more convenient, especially on fiberglass.
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
Old 09-11-2018, 07:24 AM
BillL BillL is offline
Hand deburring like the crowd. But this might be a good time to get a 1/4" shaft single hole deburring tool. You can use it on the plexiglass later. It will leave a nice smooth, concentric CS.
Bill
1st Flight 1-27-18
Phase II 8-3-18
Repairman 11-15-18
Instrument Currency 12-17-18
Shrunken Exit = ??
No Photo? => PM me.
Old 09-11-2018, 07:25 AM
Mudfly Mudfly is offline
I use a variable speed drill and a countersink bit for almost all my countersinking needs. I keep the drill speed very slow and just keep checking for correct depth with a rivet. After several, I normally can get the proper depth after a couple checks.
Shawn Edwards
RV-14A (140174)
www.myrv14build.blogspot.com
2019 VAF Donation Complete
Old 09-13-2018, 03:33 PM
Erimo's Avatar
Erimo Erimo is offline
I countersunk witout cage. Well.
Eric
RV 14A - #140252 - Flying
France
2018 dues paid
Old 01-15-2019, 09:34 PM
MonkeyWrench MonkeyWrench is offline
Wish I saw this a few days ago. I figured out how to CS by hand with a deburring tool. Came out ok. Happy to say, i use a cage on all my other CS work.
One quick note, If you use a back rivet set on the manurfactured head of that rivet, use electrical tape on the manufactured head and push real hard. Or, your manufactured head will bulge up.
Rich
RV-14A
working on empennage
EAA Chapter 186
