Old 09-08-2018, 03:23 PM
JBHansen JBHansen is offline
Default RV12 Main Wheel Inflation
Any ideas on how I can access to the main wheel valve stems with the fairings on? The nose wheel was easy, I just drilled a hole in the fairing. On the mains that would fall right in the seam of the front and back fairings. Anything else I can do?
Old 09-08-2018, 03:41 PM
Piper J3 Piper J3 is online now
Best to remove fairings to check tire pressure. Also good to look at brake linings at same time. See Tire Problem thread... http://www.vansairforce.com/communit...d.php?t=163817 where OP took shortcut and had a bad day.
Hinckley, Ohio (1OA2)
EAA #499867
RV-12 Bought Flying Oct 2015 with 48TT - Hobbs now 421
LSRM-A Certificate 2016
Special Thanks... EJ Trucks - Crew Chief A-4 Skyhawks
and MJ Stricker (my flight instructor) - 1st Lt./Captain B-17H WWII
Old 09-08-2018, 04:08 PM
Dave12 Dave12 is offline
If you remove your fairings and the mounting brackets then assemble them on a workbench, you will see a large hole on the outboard bracket. If you transfer/matchdrill that hole through the front fairing you will be able to check inflation and service the tire without removing the fairing. I use a truck tire inflator and just roll the wheel backward or forward to get it in the right position. You can also purchase an flexible inflation hose that will thread right on to the valve stem. You have to leave the stem caps off of course. You can cover the hole with a large hardware store snap cap.
Wag Aero Sport Trainer
N588DF RV12 #336 Sold
N73DF RV12 #244 Flying/ For Sale
Old 09-08-2018, 04:26 PM
DBRuth DBRuth is offline
Default Tire/fairing access
My main fairings have the access holes in the rear section, just above the internal mount. I used a laser pointer aimed at the tire stem (with the fairing off,tire chocked). Reattached the rear fairing, marked the spot from the laser pointer, and drilled the access hole there. Then I used a paint marker and put marks on the tire along the bottom of the fairing and also a vertical line at the part line of the front/rear fairing pieces. 3 years, 186 hours and no problems. I have a straight hose filler/ pressure gauge that will reach the tire stems. Sometimes, you must "use the Force Luke" to find the stem. Done carefully,it works fine. Saves the time of removing and replacing the fairings. I check the brake pads about twice a year, at annual and then six months later. Replaced my original pads back in June during annual (156hours TT).
N412DR
Kit 120797
First flight 8/21/15 what an awesome aircraft!
HOBBS @207
Old 09-09-2018, 08:36 AM
Thanks. I appreciate the info.
Old 09-09-2018, 04:25 PM
DaveWelch DaveWelch is offline
Default Nominations?
You have my nomination for “Most Creative Application for a Pocket-Sized Red or Green Dot Pointer Thingy”. Open for other nominations.
RV12 N951DZ
First Flight 9/23/16!
No paint yet. Working on a scheme with John Deere colors or accents.
Old 09-10-2018, 07:28 AM
Default Laser pointer
Just an old trick from my racing days. I learned it from someone else, not my original idea. Dave, do you have any paint on your plane yet? Mine has primer on the cowl and rattle can Orange on the wheel fairings, spinner and tailcone fairing. Eventually will get color on the rest. I flew to Moontown a couple years back, looked for you. I will return some day and look you up again.
N412DR
Kit 120797
HOBBS @207
Old 09-10-2018, 11:16 AM
Default Hey there!
No paint yet, life still intrudes on most plans. Will look forward to catching up with you.
RV12 N951DZ
Old 09-20-2018, 08:37 AM
dick seiders dick seiders is offline
Simplest in my opinion is remove rear pant and Fill it up.check pads each time as putting air in tires seldom required for most
Dick seiders
Old 09-20-2018, 08:51 PM
rk2436 rk2436 is offline
No,most tubes lose about a pound of pressure each month. More with temp changes. The long flexible extension hose thru the hole in the pant bracket works for me. I still pull the pants every so often to inspect everything.
