Old 09-09-2018, 04:51 PM
Mitch757 Mitch757 is offline
I bought mine from Vans and it is the McFarlane product. Price was $215 a couple years ago.
Mitch Garner
N2ET
Old 09-21-2018, 03:21 PM
randylervold's Avatar
randylervold randylervold is offline
moderator
Originally Posted by DaleB View Post
As stated, this is NOTHING AT ALL like a typical vernier throttle. Does not operate the same way at all. There would be no difference whatsoever flying with this or a regular throttle cable.
Thanks for pointing that out Dale, sorry for assuming. Is throttle creep a problem with the fuel injected iS, or only the ULS?
Randy Lervold
RV-12iS, empennage/tailcone complete, wings currently, fuse on order
RV-3B, first flight 2007 - sold
RV-8, first flight 2001 - sold
Old 09-21-2018, 05:02 PM
iS is totally different, and the iS airplane has a totally different style throttle control as well.
Scott McDaniels
Hubbard, Oregon
Old 09-21-2018, 05:49 PM
Bdalporto Bdalporto is offline
I'm building a 7 and have been looking at the vernier assist cables and have been wondering about formation flying. I have flown and didn't like the old pushbutton vernier throttle. Randy, have you looked at the https://www.mcfarlaneaviation.com/ar...sist-controls/ type cables and do you think that would be accepted at a FAST course?
Brian
Brian Dal Porto
RV-7 Tipper
IO-360A3B6D
Whirl Wind 200RV
Dynon Skyview Touch
Old 09-22-2018, 09:09 AM
moderator
Brian
Brian, I don't know. I've never had chance to put my hands on one, but the McFarlane site says "Coarse adjustments are made by pushing the knob inwards or pulling the knob outwards. Fine adjustments are made by rotating the knob clockwise or counterclockwise." When formation flying you will be making constant fine adjustments so if this throttle impairs that ability in any way then it would not likely be allowed.
Personal opinion: over the years I've learned that the throttle is your friend in landing any small aircraft in that you can make tiny little adjustments on short final to adjust your glidepath and touchdown point while still carefully managing your energy so as to not extend your rollout. I've found throttle micromanagement even more useful in the roundout and flare where tiny little adjustments can make all the difference between a smooth and short touchdown versus dropping in our floating way down the runway once you learn to use it. I discovered this while flying quite a range of aircraft from RVs to Cubs to Bonanzas.
Just my own opinion and technique, YMMV.
Randy Lervold
Old 09-22-2018, 09:51 AM
philrisl philrisl is offline
The Mcfarlane throttle feels no different than any friction push/pull throttle. The friction is adjustable. When there is any friction set, twisting the knob makes fine adjustments. I have one in my Rotax powered airplane (Rans S19) and there will be one in my current project RV9.
Old 09-22-2018, 09:56 AM
Mark33 Mark33 is offline
I haven’t installed one “yet” in the -7 that I’m building, but I can tell you it’s definitely the one I’m going with. I did get to play around with the vernier assist a little bit while I was at Oshkosh this year and I can tell you it’s as smooth as butter. I think when the say that “coarse adjustments are made by pushing the knob inwards or pulling the knob outwards” may not be the best description. It’s as smooth as any standard throttle cable with the locking nut and I don’t think you’d have any problem making those fine power adjustments on landing as you described. I just think that this throttle cable gives you the best of both worlds without any compromise.
Old 09-22-2018, 09:57 AM
moderator
There we have it, thanks for the confirmation!
Randy Lervold
Old 09-22-2018, 10:11 AM
BruceEicher's Avatar
BruceEicher BruceEicher is offline
Hey Randy,
Any better recommendations over the stock quadrant in the -8 (2 lever)?
And, looks like your signature could use some updating.
You in Seattle now?
Cheers!
Bruce, Katie, Hana and RV-8 HulaGirl
