Old 09-22-2018, 09:19 PM
Refresh my memory. What are the symptoms of heavy floats? Is there an overflow of the carb bowls onto the drip pans?
Old 09-22-2018, 09:38 PM
DHeal DHeal is offline
In my experience: Slight smell of fuel in the cockpit during climb, drip or two of fuel from carb vent tube onto pan, and perhaps a slightly rough idle.
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B 2020) - N124DH flying since March 2014 - 750+ hours (as of Apr 2019)!
VAF donation through June 2019.
Old 09-23-2018, 08:17 PM
Dave, thanks.
Rich
Old 09-23-2018, 08:48 PM
Dave12 Dave12 is offline
You can take this to the bank.
Wag Aero Sport Trainer
N588DF RV12 #336 Sold
N73DF RV12 #244 Flying/ For Sale
Old 09-25-2018, 06:58 PM
AirHound AirHound is offline
Originally Posted by n233va View Post
Has anyone bought these floats? If so, what was the weight of a new pair. Tragically, I am actually thinking of buying two pairs and paying the outrageous shipping charges. I have been through at least 8 floats so far.
What causes heavy floats? Type gas or inferior material? Ethanol is pretty caustic with plastic such as fuel filters. Are there any original OEM floats in the fleet since day one?
Doug
Old 09-25-2018, 09:30 PM
DaleB's Avatar
DaleB DaleB is offline
I think it's a materials defect. The SI listed a range of serial numbers newer than mine. We've got 415 hours over 7 years on these carbs and the floats still weigh just over 6g per pair, knock on wood. I'm glad that we've been so lucky.
Dale
Omaha, NE
Previous RV-7 project (sold)
Old 10-08-2018, 12:48 PM
mdoyle mdoyle is offline
Default Marvel Schebler MS80-430–FS Float Conversion Kit
I purchased and installed a pair of the Marvel Schebler floats. Weight out of the box was: 3.7 and 3.8 grams. They replaced a pair of Rotax floats that weighed 8.4 and 4.7 grams on removal. Needless to say I had a severe leak out of the overflow tube on my right carburetor.
Works great now.
Mike Doyle
RV-12
RV-9A, Under Construction
Xenia, OH 45385
Old 10-08-2018, 02:07 PM
Works great now.
Rotax Service Bulletin says a pair of floats should weigh less than 7.0g. Your new MS floats weigh 7.5g. Just say'n...
Hinckley, Ohio (1OA2)
EAA #499867
RV-12 Bought Flying Oct 2015 with 48TT - Hobbs now 419
LSRM-A Certificate 2016
Special Thanks... EJ Trucks - Crew Chief A-4 Skyhawks
and MJ Stricker (my flight instructor) - 1st Lt./Captain B-17H WWII
Old 10-08-2018, 05:42 PM
FYI -- data points (all weights are new / dry / fresh out of the box):
-- Old-Style ROTAX #861-184 floats = 2.8 grams each
-- New-Style ROTAX #861-188 floats = 3.2 grams each
-- MS 80-430 floats = Reported @ 3.7-3.8 grams each
ROTAX says max 3.5 grams each (7.0 grams per pair). I'm not sure if this ROTAX weight limit applies to another manufacturer's (i.e., non-Bing) replacement float. Maybe the MS has "superior floatation" characteristics? Any hydrodynamicists out there??
Old 10-08-2018, 08:41 PM
Default Float weights
I weighed all 4 of the floats with an electronic postal scale so the weights could be off some. The external appearance of the new floats appears identical to the Bing floats, but the material is different, a hard epoxy exterior. Perhaps the weight will not double in less than a year like one of the Bing floats did. To me it was worth a try considering Marvel Schebler is a known manufacturer of aviation carburetors.
Mike Doyle
RV-12
Xenia, OH 45385
