Old 09-07-2018, 08:33 AM
XLS+PAT XLS+PAT is offline
Default RV7 Tire pressure
Howdy VAF folks
I'm somewhat new to the RV7 and looking for opinons on tire pressures. I've been checking the tires at least once a month. It seems like 38psi is the sweet spot but I'm curious as to what other RV7 drivers prefer.
RV7 slider 0-360
C-150 Tail dragger sold 10/17
KHAF
Old 09-07-2018, 09:39 AM
DanH's Avatar
DanH DanH is online now
Please take this the right way..."the "search" button is your friend.
Short version, yeah, about 38 is common as a compromise between leg shake and tube life. Higher generally means more shake. Lower appears to come with anecdotal evidence of tube pinch and scuff problems. I run 50 in an 8, but I don't have to deal with leg shake.
Dan Horton
RV-8 SS
Barrett IO-390
Old 09-07-2018, 10:21 AM
lr172 lr172 is offline
I run 45 in the mains and 50 in the nose wheel on my 6A. I have wood dampers on the legs and never experienced any shimmy on the mains. Nose dances a bit, but only observable to viewers as it can't be felt.
Larr
N64LR
RV-10 in progress
Old 09-07-2018, 10:36 AM
jdiehl jdiehl is offline
Default 7A tire pressure
45 psi on all three wheels. Check every 2 months at which mains usually show about 38 psi. Surprisingly, nose wheel loses very little air.
Shimmy has not been an issue.
Old 09-07-2018, 10:49 AM
Sam Buchanan's Avatar
been here awhile
Originally Posted by XLS+PAT View Post
Howdy VAF folks
RV7 slider 0-360
KHAF
The tail draggers often run less pressure than the nose wheel RVs in order to manage gear shimmy. I ran 28 in my RV-6 tires for many years but now start at 35 and add air when they get down to about 28. If you don't have any gear shimmy at 38 that will be a good number for you. If you have shimmy you might try a little less pressure. The shimmy thing will vary depending on tire wear patterns/roundness.
And yes....tons of info in the forum archives on this discussion.
Sam Buchanan
1999 RV-6
1918 Fokker D.VII replica
Old 09-07-2018, 11:40 AM
VETE76 VETE76 is offline
i have ran 45 in my RV7 400 hrs ago. never a shimmy. never a flat. on 2nd set of recaps.
fred
Old 09-07-2018, 06:53 PM
N941WR's Avatar
N941WR N941WR is offline
35 for my Taildragger seems to work well.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 09-07-2018, 07:22 PM
Pat Stewart Pat Stewart is offline
I run 35 in the nose and 43 in the mains
Built, RV 8, RV8A, RV 10, RV12, Purchased RV7A
Restored J3Cub and PA28R180
Pecan Plantation
Eagles Nest Mentor
EAA Tech Counselor
Old 09-27-2018, 12:43 PM
Smilin' Jack Smilin' Jack is offline
VETE76 made a subtle comment on his post.
Recaps.
I use Dresser Monster Retreads and 40 PSI after 200 hours the tires look almost new.
Being a corporate pilot our mechanic would never use recaps but the airlines do all the time.. I am sold on their tires. they wear like iron.
Smilin' Jack & Anita Hunt
N507H RV7, KJZP Jasper, GA
EAA690
APRS/ WB4JKY
Retired Corporate Pilot CFI-AI, MEL
CE500, LRJT, HS25, C650, SBJT, CL60
Hunt Aviation, LLC.
Pilot Service, IPC's Biennials.
Comm Glider
Old 09-27-2018, 01:23 PM
I started with low pressure (25 psi) on my -6 and had a fair amount of shimmy. Since I upped it to 38 or so, the problem has all but disappeared.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
2019(?) RV-10
