Old 09-03-2018, 04:53 PM
goatflieg's Avatar
Default The hardest part of building an RV-8?
Ok, I'll admit it. I'm starting this thread for my own therapeutic benefit. For all you successful RV-8 builders out there: what was the most difficult part of the build? I'm asking because I've literally spent days trying to get four nuts onto four bolts (I'm talking to you, dreaded landing gear outboard bracket nuts in the Tunnel of Infamy). I really need to know if there are worse horrors that await me. Not to worry, this will not defeat me... but it is a nightmare job to try to do solo, even with a borescope camera and all the extensions and tools (stock and homemade) anyone would ever need.
Thanks for listening... or reading... whatever. MJF
Martin J Filiatrault
Clarkston, MI
RV-8 #83507 - currently working on finishing & firewall forward.
N657AR reserved
Builder websites:
YouTube Channel:
Dues paid for 2019... extra payment included for psychological therapeutic services rendered.
_______________________
Old 09-03-2018, 04:58 PM
goatflieg's Avatar
Current status: two forward nuts/washers started; working on the left aft now. Since this photo was taken, the aft bulkhead bolt adjacent to the bracket bolt has been loosened to get clearance. I can get the nut and washer onto the bolt, but despite fabrication of custom tooling, I'm unable to get the threads to catch. Spent many hours trying. Tomorrow I'll have a helper turn the bolt while I hold the nut against the bottom of the bolt; hopefully that will work. Did I mention the fuselage is upside down? It's upside down, all right. That might explain any confusion between left and right; the view is looking up from the bottom. (photos courtesy of borescope cam)
Clarkston, MI
N657AR reserved
Builder websites:
YouTube Channel:
Old 09-03-2018, 05:00 PM
N941WR's Avatar
N941WR N941WR is offline
It is the same thing for all the models, convincing the wife it is OK to spend your time and money on!
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 09-03-2018, 05:30 PM
DanH's Avatar
DanH DanH is offline
Martin, do yourself a big favor and replace or shorten the AN3's in the vicinity of the clamp bolts. Your goal is the "one full thread showing" minimum length. The extra four or five threads sticking out just gets in the way when working with the clamp bolts.
That said, I see one on each side which appears too short.
You modified the gear towers for access, or are you working through the standard round holes?
Dan Horton
RV-8 SS
Barrett IO-390
Old 09-03-2018, 05:35 PM
Mel's Avatar
Mel Mel is offline
Yep! I see several short bolts. Must have a minimum of one full thread beyond the locknut.
A&P/EAA Tech Counselor/Flight Advisor/Nat'l Test Pilot School
<rvmel(at)icloud.com>
North Texas (8TA5)
RV-6 Flying since 1993, 172hp O-320, 3-Blade Catto (since 2003)Sold
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
Old 09-03-2018, 06:26 PM
Gusmax Gusmax is offline
I had an inspector and many other folks try to tell me that you need at least 3 threads showing. I promptly show them the AC 43.13, Par 7-37, which reads; "All bolt installations which involve self-locking or plain nuts should have a least one thread of the bolt protruding through the nut."
Old 09-04-2018, 05:39 AM
Jaypratt's Avatar
Jaypratt Jaypratt is offline
Default Remove
I have had to remove , temporary, the bolts that are interfering with your missing nuts
Jay Pratt VAF #2
RV Central - Builder Assistance
Paul Revere, Borrowed Horse, & Shooter
Old 09-04-2018, 07:55 AM
sjhurlbut sjhurlbut is offline
Default short bolts
Those 'bolts' you see without threads showing are #8 screws. I left the washers off to get enough showing but the callout is correct to have clearance with the other bolts. The gear is a pain but doable. I just sat the washers and nuts on the bolts using long reach stick and tape to hold them turned from below. May have to grind socket a bit to get a good fit.
"Aerodynamics is for people who can't build engines"
Enzo Ferrari
Steve H
Cold Lake, Alberta
RV7A #70015 - C-FZQX - built - sold
RV7A #71629 - C-FSIS - built - sold across Atlantic
RV7 #70215 - C-GOJU - flying - sold
RV7 #70703 - C-GMIY - flying - sold
RV6 #60119 - C-FHBZ - built - Airventure 2016 Bronze Lindy - sold
RV10 #41779 - built emp - sold
RV8 #82842 - C-FSBG - Fastback with big hp IO-360-A1B6 10:1 - built
Old 09-04-2018, 08:38 AM
Mel's Avatar
Mel Mel is offline
They still need to have a full thread beyond the nut.
North Texas (8TA5)
FRIEND of the RV-1
Eagle's Nest Mentor
Old 09-04-2018, 11:38 AM
Tommy123 Tommy123 is offline
Default Thread
Accepted standard is one to three threads showing. Those bolts are too short.
