Old 08-21-2018, 01:17 PM
Docbru Docbru is offline
Default Changing rudder pedal position
Hi folks,
I am looking at buying a used 8. The rudder pedals on the one I'm looking at are much too far aft for my leg length and I'm wondering how big a job it would be to move them forward. Best guess is they would need to be moved about 4-5 inches forward. (This 8 does not have the adjustable pedal option.) Thanks for your input.
Old 08-21-2018, 01:53 PM
flyinga flyinga is offline
As far as I know, all 8s have adjustable rudder pedals. Some are in-flight adjustable and some are not.
I would estimate 2 hours to make adjustments to the ground only adjustable rudder pedals.
Jim Averett
RV-8
TS36 - Silver Wings
Fredericksburg, TX
Old 08-21-2018, 02:05 PM
...thanks...I should have clarified it does not have the "easily" adjustable pedals.
Old 08-21-2018, 10:46 PM
Mark Albery's Avatar
Mark Albery Mark Albery is offline
One thing to check is if there are individual reservoirs on the master cylinders. That is a popular mod as it eliminates a potential source of fluid leaking.
If so, then you could find that moving the pedals forward allows them to interfere with the firewall obstructing the rudder travel.
The solution to that would be to have a single reservoir mounted on the firewall, which is the standard arrangement. Other than that it's a straight forward job that should take less than an hour.
Old 08-27-2018, 03:53 PM
DougCronkhite DougCronkhite is offline
My 8 has ground adjustable pedals.. I would prefer as far forward as possible but the last position has the pedals hitting the firewall at full travel leaving no room for brake application in this position.. How have you guys resolved this issue?
RV-8 N188LC
Dues Paid 11/18
Old 08-28-2018, 06:53 AM
Carl Froehlich's Avatar
Have you tried shortening the rudder cables by adjusting the nut on the firewall rudder cable anchor?
Old 08-28-2018, 10:11 PM
I haven't.. I just installed the links to move the pedals forward. At this point, I barely fit in the airplane (6'5" tall, 275 pounds). I've ordered the tall pilot option and will be moving the seat back about 1.5" soon.. The forward most position on the ground adjustable pedals would give me more room for sure. I'm told this is a known issue with the RV-8 ground adjustable setup..
RV-8 N188LC
Dues Paid 11/18
Old 08-28-2018, 10:23 PM
bifft bifft is offline
I use my ground adjustable pedals in the full forward position. The pedal hit the firewall if you had full rudder and full brake at the same time before I put the brake fluid in, but haven't since. The resistance from the brake keeps it just barely clear.
Regarding the op, it is pretty easy to move the ground adjustable back, maybe 1/2 hour or so. Much easier if you take the forward baggage compartment shelf out and do it through the baggage door.
Old 08-29-2018, 12:38 PM
Yeah.. Definitely go through the baggage floor.. Way easier.to get to links that way..
RV-8 N188LC
Dues Paid 11/18
Old 08-31-2018, 08:24 AM
Default Ditto.
As above, we do most all of our adjustments and service from the front baggage well. We have air adjustable ruder peddles but it does not matter that much for service, just unscrew the bottom floor of the baggage compartment and you have it all right in front of you. As far as the peddles hitting the fire wall while adjusted to the front, both systems do that and we just get used to not setting them where they will come in contact with the fire wall. I have seen a few with a stop on the slider type, but you will find that you will mark the location that is as far forward as you can go for the ground adjustable type as you will need, once you get into the peddle well and look at that travel.
Hope this helps, Yours, R.E.A. III # 80888
