Old 07-12-2018, 10:24 AM
Originally Posted by AirHound View Post
My take they are fixed by thru bolts so immediate BLEW blades less likely...
On the same note....I'll bet cracks will be a challenge to discern....maybe need 10x magnification and or penetrant...All just guessing..
Whoa Nelly... front hub cracked in half and blades retained by shear (not tensile) strength of two remaining bolts per blade compounded by increased vibration.
Not a good warm feeling here...
Hinckley, Ohio (1OA2)
EAA #499867
80 hrs Flying Aeronca Chief 11AC N68203
RV-12 Bought Flying Oct 2015 with 48TT - Hobbs now 415
LSRM-A Certificate 2016
Special Thanks to EJ Trucks
Old 07-12-2018, 10:32 AM
AirHound AirHound is offline
Wow Nelly... front hub cracked in half and blades retained by shear (not tensile) strength of two remaining bolts per blade compounded by increased vibration.
Thinking, an even tightening/torqueing technique is most important preventative measure.
Doug
Old 07-12-2018, 10:35 AM
And I'm thinking that installing the new design hub is most important preventative measure...
EAA #499867
Old 07-12-2018, 10:43 AM
Ooooh yeah, bring it on..Probably new wt and bal calculation - built like a battleship..to counter the unknown...
Doug
Old 07-12-2018, 12:29 PM
n74846 n74846 is offline
What is the proper torque for the bolts holding to front spinner attach plate? Are the washers reusable? Thanks!
Steve at BCT
Flying a built ELSA
Old 07-12-2018, 01:05 PM
DaleB's Avatar
DaleB DaleB is offline
It's in the KAI and the maintenance manual - I always look it up and never rely on memory. The bolts use Nord-Lok washers, reusable if you have to remove them.
Dale
Omaha, NE
Previous RV-7 project (sold)
Old 07-12-2018, 02:39 PM
DHeal DHeal is offline
Sensenich prop torque values and maintenance requirements are also listed in the applicable Sensenich Installation Instructions document at:
http://www.sensenich.com/documents/
Also, be sure that you install the Nord-Lock lock washers with the proper orientation -- see Sensenich Installation Manual - Figure 4.
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B) - N124DH flying since March 2014 - 740+ hours (as of Mar 2019)!
VAF donation through June 2019.
Old 07-12-2018, 05:09 PM
KALEWIS's Avatar
KALEWIS KALEWIS is offline
Default Newer style Hub PN
Is there a PN for the new style hub? I am guessing it requires the blades sent off to be repinned?
Could not find a PN or price on Sensenich website for the hub only.
Have not looked in the KAI yet, anyone know off hand what size the Nord-Locks are? 9/16" or 1/2" is a guess.
Airspeed, Altitude, or Brains...you need at least two
RV-12 #328
At 435 Hrs on the Hobbs
Old 07-12-2018, 06:59 PM
Originally Posted by DHeal View Post
I inspected my front hub cover i/a/w the SB and found what appeared to be two cracks in the areas indicated in the SB -- the cracks are very difficult to see. I shipped the hub to Sensenich for their evaluation. My 4.5-year-old RV-12 has 650 hours, the prop was dynamically balanced, and the prop has not been used for pushing/pulling the aircraft on the ground. It will now be interesting to see how Sensenich responds to this issue and how long impacted aircraft will be grounded.
DHeal -
Were you able to inspect the front hub per the SB with the front spinner plate remaining in place or did you have to remove six thru bolts, spacers, and then the front spinner plate?
EAA #499867
Old 07-12-2018, 07:04 PM
I have set blade pitch on one of the new hubs and it isn't necessary at all to use the rough-in pins for setting initial pitch - just position blades by hand. So my guess is if one were able to get a new design hub with the three smaller holes the existing prop blades can be used as-is.
EAA #499867
