Old 06-23-2018, 09:25 PM
DaveO DaveO is offline
Default Oil Canning
I have oil canning between the first and the second of the right side of the tail cone.
I thought about purchasing some stiffness and installing them in the middle of the part that oil cans.
When i push in from the outside I can see a indentation of the skin. I think if the support that portion of the stop I can stop the event.
What do many of you think, or is there a more practical way of dealing with this issue.
Thanks in advance for your help
RV-7A N1243A Sold
#140479 RV-14A N1479B Reserved
Old 06-23-2018, 09:41 PM
bkervaski's Avatar
It's common, I've seen it in more than a few RV's. Mine has some, not very noticeable but definitely there. The J-Stiffener is what caused mine, not perfectly straight, there is a slight twist in it.
Progress: Flying!
Old 06-24-2018, 06:54 AM
Reflex Reflex is offline
Dave,
Not sure exactly where you mean, but I'm thinking you're describing the area between the most forward bulkhead and the second bulkhead. If so, I have the same issue. Although shown on the left in the picture below, mine too is on the right side.
I discovered mine while the cone was still upside down on the sawhorses and before I riveted. After taking the entire assembly apart four times and putting it back together in a different order (top to bottom, bottom to top, front to back and back to front). I decided that there was nothing I could do about it. I hoped that it would go away after riveting, but it didn't.
As described by Bill, the oil canning is very slight. I decided to live with it and add some sort of stiffener later if it really botheres me. Would take almost nothing to make it go away.
Picture below shows the location.
Dues Paid for 2019
RV-14
Empennage Complete
Getting Ready to Close Wings
Old 06-24-2018, 02:37 PM
Aluminum Aluminum is offline
Me too, but on the left side. Keep us posted on the results if you do decide to add extra stiffeners. A piece of butyl or foam acoustic damping material might be enough to prevent canning in practice. Then again, this is not the easiest place to reach once it's all buttoned up.
Dan V
'91 Zodiac flying since 2013
RV-14A in progress
2019 dues worth every penny
Old 06-24-2018, 03:02 PM
bkervaski's Avatar
Yep, same location @Reflex posted on mine.
Progress: Flying!
Old 06-24-2018, 03:26 PM
Yes, You hit the spot," Reflex" and also in behind the next bulkhead back. Both are not real bad, I think that I will live with it. Though, as I look down across the outside of the metal I can see a small what appears a dent. I do not like that.
I followed the instructions in the order of riveting, but it still happened.
In reality, unless one is looking for that effect, I do not think it would be a issue.
Thanks for all your input to the situation, my post left words out as I did not read it before I posted.
If I change mind and try to fix the situation I will repost.
RV-7A N1243A Sold
Old 06-24-2018, 09:52 PM
KeithB KeithB is offline
You won’t get a much clearer example than this.
This was taken during Phase I fly off. I had similar examples on the other side - definitely exacerbated by pressures during flight.
To fix it, I cut segments of J-stiffener and mounted them between the bulkheads, parallel to the horizontal stiffeners, held to the skin with pro seal - six pieces in all.
Keith Brown
RV-14A Builder - kit #136, XP-400 Aero Sport Power
N314KC - First flight Mar 8, 2017, 24th in the air, >400 hrs
RV-6A sold
Sport Pilot (weight-shift control) - Airborne XT912
Dues paid 12/2018
Old 06-25-2018, 05:37 AM
Keith...simply put....WOW!
Dues Paid for 2019
RV-14
Empennage Complete
Old 06-25-2018, 05:43 AM
Mel's Avatar
Mel Mel is offline
Any time you add a stiffener between bulkheads, be sure to secure that stiffener to the bulkheads at each end. Otherwise a crack will develop over time at the end of the stiffener.
A&P/EAA Tech Counselor/Flight Advisor/Nat'l Test Pilot School
<rvmel(at)icloud.com>
North Texas (8TA5)
RV-6 Flying since 1993, 172hp O-320, 3-Blade Catto (since 2003)Sold
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
Old 06-25-2018, 07:24 AM
JDA_BTR JDA_BTR is offline
Might be fun to come up with a paint scheme that makes the flaw a feature.
Ser 104142, RV-14A
N1463
Ready to gas it up!
Urologist, AME
