Old 05-03-2018, 11:21 AM
transientair transientair is offline
Default Beringer Nose Wheel
I've ordered the finishing kit for my 14A and thanks to the good folks who have posted a heads-up about the issues with the nose wheel provided in the kit, I deleted the U-1009 axle and NW501.25 nose wheel with the intent of replacing them with the NW511.25 nose wheel and Matco WHLAXLE24 axle.
However, I'm also interested in the Beringer nose wheel. Does anyone know if the one Van's sells for the -10 would work for the -14A too?
Assuming this Beringer nose wheel would work on the -14A, would the Matco axle work with it?
Old 05-03-2018, 02:21 PM
Cody---the Beringer Nose gear kit is the same for the 10 and the 14A, by the part number. But I would definitely check with Carla about the axle.
Tom
Ridgeland, SC
Old 10-09-2018, 04:49 PM
Stockmanreef Stockmanreef is offline
do you order order directly from Beringer or from Aircraft spruce?
Ken Stockman
Midland, MI
EAA Chapter 1093 member
RV-14 (serial number 140073)
N73XP (at least that # reserved now)
Old 10-09-2018, 06:35 PM
MED MED is offline
I bought everything directly from Beringer. They (Carla Panetta is the boss) are easy to deal with and I think the prices are the same.
MED
140236
N435MD
Old 10-09-2018, 07:54 PM
Tom023 Tom023 is offline
I bought mine from Vans when I ordered the finishing kit. Came in the same shipment and Vans credited all the parts I didnít need. You use the Beringer axle so donít need the Matco. Very easy straightforward installation.
RV14A #140083
Down to last 1%. Targeting June 1 for first flight.
2018 Donation+
