Go Back   VAF Forums > Model Specific > RV-4
Old 09-16-2018, 12:34 PM
spirit49 spirit49 is offline
So to finish off this post.
Which one of the FAB's would be the best one for the EFII throttle body?:
FAB-320-1 O-320 Carbureted
FAB-320 ELLISON-1 O-320 with Ellison Throttle Body
FAB-320 AP-1 O-320 with Airflow Performance System
RV-4 s/n 1403 Restoration
Dues paid 2018
Old 09-16-2018, 04:19 PM
Ralph Inkster Ralph Inkster is offline
In the end... what ever kit you choose will require you to fabricate the connection between the throttle body and top of the air cleaner assy.
You won't need the Carb Heat hardware that would be in the FAB Carbureted kit (or I assume also is in the FAB Ellison kit).
You still will need an Alternate Air source valve of some sort, so I would go with the FAB-320 AP-1 O-320 with Airflow Performance System as best choice.
Ralph
Maintain lots, upgraded - repaired - & modified more, rebuild a few, & built some too.
Old 09-17-2018, 01:09 AM
Thanks a lot Ralph
Dues paid 2018
Old 09-18-2018, 01:57 PM
rcpaisley's Avatar
rcpaisley rcpaisley is offline
Default EFII
Our throttle body flange adapter kit gives you the parts you need for this:
https://www.flyefii.com/products/acc...lange-adapter/
Robert
EFII www.flyefii.com
Protek Performance
