Old 09-26-2018, 02:53 PM
N941WR's Avatar
N941WR N941WR is offline
Interesting thread.
What about onbthe simple side of things.
I have teak grips with the PTT on the top.
If I were to add an autopilot button, should it go in the trigger position, panel, should the PTT be moved and the AP button installed on top?
Suggestions please.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 09-26-2018, 05:05 PM
RV7A Flyer's Avatar
RV7A Flyer RV7A Flyer is offline
Originally Posted by N941WR View Post
If I were to add an autopilot button, should it go in the trigger position, ... PTT be moved and the AP button installed on top?
Suggestions please.
PTT on trigger, AP on top.
2019 Dues paid!
Old 09-26-2018, 05:36 PM
N941WR's Avatar
Why?
The right stick will retain the PTT on top.
Bill R.
SC86 - Easley, SC
Old 09-27-2018, 01:32 PM
RV7A Flyer's Avatar
Why?
Because I find it easier to just "squeeze" my finger to activate PTT than to press my thumb down. It's just more comfortable for me.
I never fly from the right, so that's not really of much concern for me (plus, there's only one button on that stick anyway, whereas the pilot's stick has quite a few functions...trim, A/P, smoke, PTT).
2019 Dues paid!
Old 10-11-2018, 01:49 PM
supik supik is offline
Default TOGA GMC vs GTN
Michael,
did you find out whether it's enough to wire the TOGA input into the GMC507 or does the GTN need a dedicated input?
Originally Posted by BoilermakerRV View Post
You are correct in that it goes to the GMC 507. And that is what I intended by G3X. I think of the whole system as a the "G3X". I still think the GTN needs it's own TO/GA input. Happy to be corrected.
Igor
RV-10 in progress
Build Log
Old 10-11-2018, 02:01 PM
Ed_Wischmeyer's Avatar
Ed_Wischmeyer Ed_Wischmeyer is offline
They both need TOGA:
On the G3X, TOGA takes the autopilot to pre-programmed pitch up and wings level;
On the GTN, TOGA activates the missed approach procedure for guidance;
The pilot still has to reconnect the autopilot to the GTN on a missed approach.
On my RV-9A with a fixed pitch prop, if I'm slowed to final approach speed and go to full throttle and TOGA, the plane gets as slow as the autopilot programming will let it. This means that an autopilot go around at minimums would be interesting. However, following the lead of a jet test pilot friends, I try to avoid flying where ceilings are less than a thousand, just in case the engine poops out, so that means that I don't ever plan to fly an approach to minimums in IMC. The key phrase here is that I don't *plan* to, but I still need to know how to do it reliably. I go through the TOGA drill on every approach, and I always engage the autopilot on every takeoff, just for practice, even on a VFR flight. If I had a constant speed on the RV-9A and better acceleration, TOGA acceleration might not be as much of a factor.
RV-8 (steam gauges), RV-9A at KSAV (Savannah, GA; dual experimental touch screens with autopilot, IFR GPS)
Previously RV-4, RV-8A, AirCam, Cessna 175
ATP CFII PhD, so I have no excuses when I screw up
2019 dues slightly overpaid
Retired - "They used to pay me to be good, now I'm good for nothing."
Old 10-15-2018, 02:00 AM
Default TOGA GMC507
As the GMC507 is connected via CAN Bus to G3X, no dedicated/discrete input is needed for the G3X. The question is if the G3X can trigger the Missed Approach Proc on the GTN remotely..
Igor
RV-10 in progress
Build Log
Old 10-26-2018, 04:18 PM
Here is the answer to my question..
Let me know if the image is not displayed.
Igor
RV-10 in progress
Build Log
Old 10-26-2018, 04:31 PM
..can't find the TO/GA discrete input wiring in the GTN install manual dated dec2012, rev.4
Igor
RV-10 in progress
Build Log
