Old 01-07-2018, 07:55 PM
Bavafa Bavafa is offline
Default switch use on the stick
A question for the G3X users, just wondering what functions are available and advisable for using either a momentary or toggle switch on the stick. I will have two of them on my pilot side and one is going to be a momentary switch for A/P control wheel steering/disconnect. I am wondering what other functions are available with this or a toggle switch? I am considering "Ident" for transponder as a possibility.
Thoughts?
Thanks in advance
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 01-07-2018, 09:45 PM
RV7A Flyer's Avatar
RV7A Flyer RV7A Flyer is offline
Smoke system!
2019 Dues paid!
Old 01-08-2018, 03:56 AM
tgmillso tgmillso is offline
I went through everything when I put my wiring plan together and the only thing I could find worthwhile was using my spare button on the stick for engaging the autopilot wing level/alt hold (see pg 33-131 of the manual). It essentially replaces the LVL button on the GMC 307 autopilot controller, if you chose to do your install without the separate controller. It's my "hey buddy, will you hold this for a second" button, so I can quickly engage the autopilot without having to flip through anything on the screen.
If you search through the G3X install manual for the term "discrete input" it will lead you to a number of options dispersed throughout the manual, such as "manual reversion" for switching between ADAHRS, Take off/Go around, frequency swap, Electronic Stability Protection etc.
Tom.
Old 01-08-2018, 05:59 AM
Deweyclawson Deweyclawson is offline
Default KISS
Keep It Simple S*******.
Put only those functions on the stick/throttle that are needed to help fly the plane. Functions that you really don't want to move your hands/eyes to perform. The ident button is NOT one of those.
Trim, transmit, smoke on/off, speed brakes/spoilers, auto pilot disengage (maybe), Nose wheel steering, are all good candidates.
I shudder when I see someone has put a start switch on the stick. If inflight restarts are done several times on each flight, this might be a good idea, otherwise....NO.
If you have to think about which finger to move to perform a function, then that function should not be at your finger tips.
Dewey Clawson
Super Sabre Society
2012 RV10; 1993 RV6A; 1947 Cessna 140, in progress
2019 dues exempt but paid anyhow
F100, A7D, A10, F16,
Fokker, Boeing, McDonnell-Douglas
Old 01-08-2018, 06:06 AM
BruceMe's Avatar
BruceMe BruceMe is offline
Cool Stick controls
Put AP and back channel swap. That's all you need. Also if you aren't familiar, learn course steering (hold down AP), it's nice.
Bruce Meacham
Built/Own RV-4 254MM
Restored RV-6 4074V
First RV RV-3 3456B
VAF annual donation on autopay
Old 01-08-2018, 06:22 AM
Auburntsts's Avatar
I have an Infinity grip so lots of buttons/switch options. Regardless of the grip brand you have, I agree on keeping it limited to switches that you want to access without having to look for it. The top of my sticks have the A/P Disconnect/Control Wheel Steering (CWS), Trim (coolie hat), and Flap switches. My "trigger" switch is the PTT. I also have an VP-200 ack on my thumb switch (don't use it anymore and haven't reassigned it to anything else) and Com 1 flip-flop on my pinky (I never use it as I'm in the habit of doing it right on the radio as I'm usually dialing in a new freq right after the change).
PS-- I've been asked to "ident" exactly once in the past 200 hrs (and I'm based in the DC SFRA in Class D under Class B and fly IFR frequently); my point is it doesn't happen enough to warrant placement on the stick. YMMV....
Todd Stovall
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 01-08-2018, 06:59 AM
Thank you all for your input. I won't have smoke system otherwise this would be good option.
Mehrdad
Dues paid
Old 01-08-2018, 07:12 AM
Walt's Avatar
Walt Walt is offline
Big fan of simple myself. I added 'ident' last year when I started doing a bunch of IFR work. I'm under the class B and have lots of class D fields around with radar and was asked to ident quite a bit. The ident button has come in very handy. Other than trim and PTT, I have AP disc and ident.
Walt Aronow, Dallas, TX (52F) RV7A, IO370, C/S, 1500+hrs
EXP Aircraft Services LLC
Old 01-08-2018, 08:48 AM
Toobuilder's Avatar
I have an Infinity "fighter style" grip festooned with switches and have to admit having a hard time finding a function for all of them. Trim, flaps and Radio transmit are obvious, in addition I have AP, smoke, and freq. flip flop.
The smoke replaced my first foray into the "Start" function on the stick. I debated that one quite a while and eventually found it useful on the Rocket, which can be a handful to hot start while holding the stick firmly back. Since I'll be EFI from here on out, the start button on the stick makes no sense. Besides, an extra button makes a good excuse to add a smoke system, right?
Michael Robinson
______________
RV-8 - Flying
Old 01-08-2018, 09:54 AM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is offline
I'll be using Dynon, but as another data point here is the setup I'm going with on my Tosten grip.
Carlos in Arizona
EAA Chapter 538 President, www.538.eaachapter.org
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
