  #31
Old 10-02-2018, 10:05 AM
climberrn climberrn is offline
I have read the thread and am very interested in upgrading. It seems like you guys are just upgrading the disks (rapco), making the spacers so it fits properly and upgrading the o rings on the stock matco calipers. Am I missing something? Need to change the master cylinder or calipers? I see the Cleveland kit for $700. Are you getting that also, or just getting the disks separately and making your own shims?
Sorry if it’s need answered before, but I just couldn’t figure it out.
Joel
N626JA
RV-7A at CXP
Flying!
Old 10-04-2018, 09:26 AM
krw5927 krw5927 is offline
Hey climberrn, here's what I did:
Purchased the new thicker Rapco discs and installed them on the wheels.
Fabricated a 1/8" thick aluminum shim, same shape and hole pattern as the gold Matco caliper spacer, to put the calipers 1/8" further apart to accommodate the thicker discs. Bought new AN4 caliper bolts, 1 grip length longer, to account for the new spacing.
Bought (actually a kind forum member sent me his spares) two arbor shims to fit on the inside of the axle (one on each axle), along with the Vans spacer, to put the wheel 1/16" further outboard. This helps to keep the thicker disc from hitting the wheel pant mount bracket and keeps the centerline of the new disc in the same location as the centerline of the old disc, so your calipers are happy. Someone else recommended part number 5GA99 from Grainger. That looks like it'll work.
Then you'll have to shave either the outboard axle spacer or the axle nut by the same amount (1/16") to keep the wheel pant from getting stretched and possibly cracking. I chose to shave the inboard side of the wheel nut. With some careful attention, you can even get the cotter pin holes to line up where they were before and still have the right compression on the bearings.
Once this is all done, check that the inboard wheel pant bracket isn't rubbing on the new disc and that all is still rotating and working freely. On my plane this all fit OK, but inspect carefully because you're stuffing more junk into the same space and possibly changing geometry in an already tight area.
I didn't do anything to my O-rings.
Edit: I may have mis-remembered on the thicknesses. Since other posts seem to indicate the new disc is 1/4" thicker than the original stock, you'll need to shim the caliper by that amount and get new caliper bolts to take up that extra distance (2 grip lengths for 1/4"). Then the arbor shim would be half that (1/8") and the axle nut would be shaved the same amount (1/8"). Bottom line, measure the thickness of the new discs relative to the originals (when they were new) and shim for the difference. Be careful not to shim too much, or as the pads and disc wear you might push the piston out of the caliper or un-seat the piston o-ring before the pads contact the disc, losing all braking action.
Kurt W.
RV9A
FLYING!!!
Old 10-04-2018, 10:02 AM
Awesome. For some reason I thought you were changing the calipers also. That clears it up!
Joel
N626JA
RV-7A at CXP
Flying!
Old 10-04-2018, 03:50 PM
Edited the numbers in my previous post.
Kurt W.
RV9A
FLYING!!!
Old 10-12-2018, 07:53 PM
Originally Posted by Northernliving View Post
These appear to be a pretty good price for new discs - $87/each.
https://www.ebay.com/itm/BRAKE-DISC-...IAAOSwgQ9V1aRk
Also here for about the same price
http://www.chiefaircraft.com/ra-164-01700.html
FYI, these are not the thicker disks discussed in this thread.
Joel
N626JA
RV-7A at CXP
Flying!
Old 10-13-2018, 12:33 PM
gasman gasman is offline
Here are the CORRECT parts to make this conversion.......
Aircraft Spruce.........need 2... 06-01311 Rapco Brake Disc RA164-09900
Aircraft Spruce........ need 1... 06-00651 Rapco RA66-106-4K brake line kit
Aircraft Spruce.........need 4... AN4H-16A AN Bolt
Granger...................need 2... Arbor shim,0.1250x1 1/4 ID. Granger sells a pack of 10 only 5GB11..... so shop around.
Why do you need an 1/8" arbor shim?? When you install your home made 1/8" spacer between the pad plate, it moves the entire brake cylinder 1/8" closer to the pant bracket. Test fit for scraping. If it does not scrape, you may not need the shim. The 1/8" arbor shim will move it back to it's original location. So if it didn't scrape before, it won't scrape after. But now you have pushed everything 1/8" out the axle. So you must remove 1/8" from the face of the nut to bring it back to it's original location.
ACE hardware..... (or any hardware store) Alum-flat 1/8" X 1" to make spacers to move pad plate out.
Local Hydraulics shop....need 2... Viton "O" rings for piston. Viton # 568-218. https://mykin.com/orings/as568-218-viton-75.html
Machine .125 from the face of the nut to make up for the shim and allow the cotter pin to line up with existing hole in the axle.
VAF #897
2019 =VAF= Dues PAID
Old 10-23-2018, 08:33 AM
whd721 whd721 is offline
Thanks to all who have added their knowledge to this thread. I started it to help others avoid the hours of searching required to complete this upgrade.
I have been happy with the conversion. After much thought during and after the conversion, I came to the conclusion that I was dragging the brakes during taxing and take off. I started to go through a little dance at the start of take off, to align on the centerline and then move my feet to the outside lower corner of both rudder peddles. Even with this technique I would occasionally notice the RV9A would lurch on liftoff.
My final modification was to add the Anti Splat Aero Rudder Pedal Extensions. Now I can feed right rudder without adding right brake also. The ball of my feet is above the lower cross bar of the rudder peddles and allowed unintentional brake application.
I recommend you consider this peddle extension mod. It finally solved my problem.
whd721
RV9A
Sherwood, Oregon
As Bill Stout (designer of the Ford Trimotor) used to say, “Simplicate and add Lightness”
