Old 10-19-2018, 04:15 PM
Erimo's Avatar
Erimo Erimo is offline
Default RV14A F-PJEM panel
This panel tends to become conventional now but it's like I dreamed it
Dual G3X Touch, GTN650 (COM1), GTR 20 remote (COM2), GTX 35 remote, GMA245, GMC307, GAD27, G5 as backup flight instrument with battery, TCW backup battery for PFD, GTN and GEA24.
Eric
RV 14A - #140252 - Flying
France
2018 dues paid
Old 10-19-2018, 07:32 PM
springer springer is offline
Very nice Eric. I am always amazed at the quality of the European builds.
Jim
RV-4 '88-'09 Built & Sold
RV-8 Purchased
Old 10-23-2018, 05:44 PM
kiljoy's Avatar
kiljoy kiljoy is offline
Default Phase I
I'm very proud of this. I used the spare wing walk doubler I had for a panel. It was perfect since the pre drilled holes were already lined up
- Kilroy
Dues paid (2019)
RV-14 #140394
Empennage - done(ish)
Wings - done(ish)
Fuselage - Somewhere in Ch. 26
YouTube Build Channel
Old 10-23-2018, 06:11 PM
mturnerb mturnerb is offline
- Kilroy
Now that's confidence inspiring!
Turner Billingsley
RV-14A In Progress
N14VB Reserved
Old 10-23-2018, 07:30 PM
Bavafa Bavafa is offline
Very nice panel indeed.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 11-03-2018, 04:15 PM
MED MED is offline
Default Smoke Test
MED
140236
N435MD
Old 11-09-2018, 07:07 AM
mountainride mountainride is offline
Default Panel Plan
Pilots Side:
Engine Start Push Button
ELT Control (Not Shown)
Master
Avionics Master
Autopilot
Boost Pump
G3X
Flap Switch
Center Console
G5
GMC507
GTN625
Nav
Strobe
Landing
Taxi
Defost
Pitot
Right Side:
Ipad 12.9"
Small Glovebox for pens,glasses etc
The plan is to run as simple a panel as possible. All switches are Carling Contura Backlit and Laser etched by rockerswitchpros. Single Battery, Single Alternator with VPX Sport controlling the 12v electrical system. The G5 will have a battery backup as well as having an Ipad/Sentry combo for redundancy. The flap switch is a lit toggle switch as well as engine start. Every switch is lit and laser etched to do away with panel labels. I am hoping I can use the built in intercom of the GTR20 instead of a remote comm panel.
Behind the panel, GTR20 x2, GTX45R
RV-14 Builder
https://rv14mountainride.wordpress.com/
Old 11-09-2018, 03:08 PM
mjanduda's Avatar
mjanduda mjanduda is offline
Have you checked if you have enough room behind the panel for the G5 and for its screws?
Old 11-10-2018, 06:00 AM
ShortSnorter ShortSnorter is offline
Originally Posted by mountainride View Post
Pilots Side:
Master
Avionics Master
Autopilot
Boost Pump
G3X
Flap Switch
Center Console
G5
GMC507
GTN625
Nav
Strobe
Landing
Taxi
Defost
Pitot
Right Side:
Ipad 12.9"
Please keep us updated -E agerly following this!
Ryan
RV-14 In-Progress
Build Site
Old 11-10-2018, 10:18 AM
RV-14E's Avatar
RV-14E RV-14E is offline
Greetings.
Be careful that the Canopy Close-Out doesn't impinge on your instruments behind the panel when the canopy closes. The Close-Out is the gray box-like area with clecos in this picture:
Also, be careful that the C-01404-L/R Support Flanges don't overlap any part of your panel devices when the canopy is closed. In the above picture, that's the gray part that on the top underneath the glareshield.
As an example, I put dual 12.1" GRT HXr EFISs in my panel. They had to be aligned to the bottom of the panel so that the canopy could close. My steam ALT on the right actually just contacts the aft edge of the Close-Out when the canopy closes (if you look real closely, you can see a bit of white on the edge of the Close-Out which is where the paint was rubbed off and now exposes the primer).
I see you're in Colorado. PM me if you'd like to take a look at my bird to get a better perspective on what you need to watch out for when placing instruments on the panel.
E
http://rv-14a.blogspot.com/
