Old 12-29-2014, 08:33 AM
jswareiv jswareiv is offline
Default Error on Page 29-19
Step 5 says to Machine Countersink the holes in the F-01405K Guides. See Figure 2.
Step 6 says to Dimple the holes in the F-01405K Guides. (Same Part)
Drawing says to do what's in #5. Actually you want to dimple F-01405K and CS F-01405H
I notified Van's and a change to the plans will be made. I don't think anyone mentioned it yet.
Stoney
First RV-14 Flight 04/17/2016
Serial #140087, N214SW - Sold
Old 09-27-2018, 09:32 PM
iamtheari iamtheari is offline
Resurrecting this old thread because there is still an error on this page in revision 1, which is dated 3/3/2015 (2 months after the post above).
The written instructions have been corrected from the post above and now say:
Step 5: Machine Countersink F-01405H shims
Step 6: Dimple F-01405K guides.
But the drawing has a label "MACHINE COUNTERSINK, TYP" which erroneously points to the F-01405K guides instead of to the F-01405H shims.
Old 09-28-2018, 04:30 AM
mturnerb mturnerb is offline
I honestly don't remember what I did when I came to this section but I have two questions:
1. Is the shim material thick enough to countersink? It would seem obvious if a part is too thin..
2. If you did mistakenly countersink rather than dimple a shim, would it matter? The shim is there to take up space and doesn't seem to have any significant structural function.
Turner Billingsley
RV-14A In Progress
N14VB Reserved
Old 09-28-2018, 03:50 PM
The shim is thick enough to countersink for the AD3 rivets that go there. I dimpled the guides and will countersink the shims. If you dimpled the shims (also possible, I think), then you could just countersink the crossbar that the guides and shims rivet on top of.
Old 09-28-2018, 05:20 PM
I looked at the wrong version of the plans!
Turner Billingsley
RV-14A In Progress
N14VB Reserved
Old 09-28-2018, 05:22 PM
Makes sense - I think I followed the written instructions so it wasn't an issue.
Turner Billingsley
RV-14A In Progress
N14VB Reserved
