Old 10-11-2018, 09:18 PM
lr172 lr172 is offline
Default Dealing with skin gap at Tie Down Blocks
My QB wings have about 1/8" gap between the skin and the bottom edge of the long threaded block that the tie tie down ring screw into. If I don't deal with it, the skin will deform (probably not permanently) when I tighten a lock nut. I would like to get something in there to bridge the gap.
I am thinking JB weld or epoxy and have some ideas on doing it without it getting into the threads. However, I am curious if someone in the group has come up with a good idea for dealing with this.
N64LR
RV-10 in progress
Old 10-11-2018, 09:38 PM
wjb's Avatar
wjb wjb is offline
The trick I used for my 7 is to screw in a set screw to limit the depth of penetration of the tiedown ring shaft. This way, you can get the tiedown ring flang (if you have one) right up against the skin.
Bill Bencze
N430WB RV-7 #74152, tip-up. Working the baffles
Log at: http://rv7.wbencze.com
Defeating gravity one rivet at a time
VAF 2019 donation happily made
Old 10-11-2018, 09:39 PM
Use a dremel to enlarge the hole in the skin. You'll get a structurally better connection that way and won't deform the skin.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 10-12-2018, 07:18 AM
Carl Froehlich's Avatar
Put a sleeve on the tiedown so that it acts as a stop. Another simple way is to use JB weld on a few threads next to the ring.
If doing a slow build wing move the tie down block lower so it is flush on the inside of the wing. Add a rubber washer on the tiedown ring to protect the paint.
Old 10-12-2018, 07:30 AM
ALagonia ALagonia is offline
I added a rubber grommet to the base of the tie down ring on my 9. Seems to work fine.
Old 10-12-2018, 09:05 AM
cholladay cholladay is offline
I did what Kyle said. Enlarged the hole.
Chad Holladay
Heritage Airpark TE86
RV-8 N769CE Sold
RV-10 N529W flying
RV -8 Building
Old 10-12-2018, 10:21 AM
wirejock's Avatar
wirejock wirejock is online now
Default Tie down bracket
If the wing is still open, replace the brackets and install them so they are flush. That's what I did.
Cleveland sells a kit with three brackets and rings. Brackets are pre-tapped.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 12/27/2018. Plus a little extra.
Disclaimer
Old 10-12-2018, 11:13 AM
John Tierney John Tierney is offline
For my tail tie-down I found a nylon shouldered washer/spacer in the hardware store that I wedged/popped between the inside of the skin and the bracket. I think I had to file the nylon a little and adjust the skin hole size.
Looks like this: http://wedo.hillmangroup.com/viewite...oulder-washers
John Tierney
Salem, WI
RV-7A - Final Assembly
N777JT
Old 10-12-2018, 12:55 PM
If it were me, I'd do the same trick, but with an aluminum 'shim'. Cut to fit, drill slightly oversize hole, slide into place, screw in the tiedown, and proseal or RTV around the edges to the skin and between the shim and the anchor extrusion.
Hint: You can shave a 1/4" thick slab of aluminum to whatever thickness you need on a table saw with a carbide blade. (Goggles & gloves advised...)
Old 10-12-2018, 01:11 PM
Paddy's Avatar
Paddy Paddy is offline
Default Tie-Down Shim
This shim was riveted onto the skin before she skin was riveted to the spar.
However, I think that skin is already riveted on the QB wings, so another method of getting the spacer in there would be needed.
Flying as of 10/30/16 after 8 yrs building
