Old 09-26-2018, 09:09 AM
Bavafa Bavafa is offline
Default EarthX battery
I was wondering how many have chosen EarthX battery for their 14 and which model was chosen, the 680 or 900.
I am planning on getting the EarthX but unsure of which model. Do I really need a 900 for the IO390 or simply an overkill?
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 09-26-2018, 09:41 AM
Carl Froehlich's Avatar
While cranking amps is a consideration, battery reserve (amp-hours) tends to drive selecting battery size.
Decide how many hours of flight you want to have on battery power alone. If this will be an IFR plane, strongly recommend a two battery design scheme. Identical batteries are, in my opinion, advantageous over mixed.
Old 09-26-2018, 01:10 PM
JohnInReno's Avatar
JohnInReno JohnInReno is offline
Default Alternator size
My understanding from talking to EarthX is that the alternator output determines the size. The 680 is limited to 60 amps and the 900 is sized for 70 amps.
Call EarthX to confirm.
John Morgensen
RV-9A N946PM 600+ hours since 2013
Nevada/Arizona
Old 09-26-2018, 01:33 PM
AX-O's Avatar
AX-O AX-O is offline
I have a 60A alternator and I run an EarthX 1200. I wanted to remove my secondary battery so this was the best way to go for my system. Kathy is AWESOME. Give her a call.
This battery has operated well thus far. it is hanging on my firewall on the FWF side.
Axel
RV-4 fastback thread and Pics
VAF 2019 paid VAF 704
The information that I post is just that; information and my own personal experiences. You need to weight out the pros and cons and make up your own mind/decisions. The pictures posted may not show the final stage or configuration. Build at your own risk.
Old 09-26-2018, 01:54 PM
schristo@mac.com's Avatar
schristo@mac.com schristo@mac.com is offline
Default I would go with the 900 but he 680 is adequate...
I have been running the 680 for several years and more than 600 hours and it is adequate for a 390 but if I had it to do over again I would go with the 900 for the extra reserve and depth of charge.
Stephen
RV7 powered by a lycoming thunderbolt IO-390
turning a whirlwind HRT prop
flying with almost 2,000 on the hobbs!
Race 771
margarita!
Old 01-19-2019, 11:10 PM
dmattmul dmattmul is offline
Default Location
If you are placing the battery on the inside firewall (I am for the second battery) consider using this: ETX900 Vent I have been a long time user of Lithium based batteries and have seen one very small battery emit a lot of noxious fumes.
RV-14 QB building, Lycoming 390 Thunderbolt arriving Feb 2019, EFII-32 Ignition and Fuel, hope to be flying fall of 2019 !! Dues paid+ of course !!
