Old 08-19-2017, 09:17 AM
vfrazier's Avatar
vfrazier vfrazier is offline
Blake has a nifty tool that is useful for installing the cowling. Rent or buy it here.
The tool mounts to the face of the crankshaft/flywheel on commonly used Lycoming and Continental engines. It has an adjustable disc that simulates the spinner position. The cowling can be clamped, or clecoed, to the disc while you trim, fit, drill it to the airframe, or other cowl half. This allows the cowling to be positioned very accurately and solidly while working on it.
You could even install the cowling before you buy your prop. Of course, you need to know the dimension from the flywheel face to the back of whatever spinner you plan to use. Planning and common sense required!
Anyway, it's a very handy tool that eliminates the need for you to cobble together a homemade tool, or actually work around an expensive prop/spinner.
Obviously, you need to have the engine hung to use this tool! Doh... I hate to have to point that out, but someone will ask!
YMMV, but many of you may find a tool like this very useful and time-saving.
Vince Frazier
www.f1aircraft.com
F1 Rocket and F4 Raider components
www.flyboyaccessories.com
RV and Rocket Accessories, Tailwheels, Tools, & More
1-888-8FLYBOY (1-888-835-9269)
F4 Raider - under construction
F1-H Rocket "Crazy Horse" - sold
RV-4 "Chief Pontiac" - sold
Old 09-21-2018, 12:45 AM
Gandalf Gandalf is offline
Default Increasing Cowl To Spinner Clearance
After dry fitting my spinner, I appear to only have only about a 1/16 inch of clearance between the spinner bulkhead and cowl. On the other hand I have good clearance for the exhaust pipes and oil lines .
So I pulled the lower plugs and used cleco clamps to position the spinner on the bulkhead, centering the spinner.
After speaking to the folks at the mother ship, I purposefully "tried" to place the holes in the spinner bulkhead slightly forward of the midline to allow a little sanding of the bulkhead if needed. Most of the holes ended pretty much in the midline and at least none were aft of the midline. I also ordered the S-1210 spacer which moves the entire spinner assembly forward a tiny bit. Hopefully the combination of sanding the spinner bulkhead and installing the S-1210 spacer will give me the magic 1/8 inch clearance.
Jeff
Old 09-21-2018, 09:16 AM
magiccarpet's Avatar
magiccarpet magiccarpet is offline
My clearance is 5/16" which to me seems just right and nice when comparing to other aircrafts. I aimed for a larger gap than stated in the KAI. I also installed the engine first prior cutting the cowl and never regret it.
Just my 2 cents
Chris, RV-12 HB-YSC
Phase I
Facebook: http://www.facebook.com/magic.carpet.aviation
12-Town:http://12town.com/profile/Chris
=VAF= dues paid for 2019
Old 01-21-2019, 10:20 PM
Default Need to remove spinner to remove cowling?
F/U... Just a heads up and a ?. When I installed the top cowling this pulled back the lower cowling so that I now have 3/16 inches of clearance from my spinner using the optional S-1210 spacer.
Now for my ?. I do not see how I can set the most medial screw holding the top and bottom sections of the cowling together without removing the spinner. This would seem to imply that I must remove the spinner every time that I wish to remove the cowling. Is this correct?
Jeff
Old 01-22-2019, 04:56 AM
Mich48041 Mich48041 is offline
No, it is not necessary to remove the spinner to remove the cowl. Something is wrong. Do you have a picture?
Joe Gores
RV-12 Flying
Old 01-22-2019, 05:35 PM
OK So there are six screws holding the top and bottom of the canopy. I placed the two most medial screws behind the spinner. My bad. Happily this is fiberglass and I can move the nut plates.
Jeff
