Old 01-03-2011, 06:31 PM
Pat Stewart Pat Stewart is offline
THE HEAVY LEFT WING DOES HAVE BOTH THE AUTOPILOT SERVO AND THE AILERON TRIM SYSTEM IN IT HOWEVER I DON'T SEE HOW THAT COULD MAKE THAT BIG OF A DIFFERENCE. I DID LEVEL THE AIRCRAFT FORWARD AND AFT BUT DID NOT CHECK IT RIGHT TO LEFT. NEXT WEEKEND I WILL CHECK THE RIGHT TO LEFT LEVEL AND RE-WEIGH IT. I WILL POST THE RESULTS. THANKS FOR ALL THE FEEDBACK.
PAT
Old 01-17-2011, 06:53 PM
aerhed aerhed is offline
Default WEighed & meaured to death
Did the weigh-in today. No gear fairings.
RM=635.4@122.75
LM=647.4@122.91
NW=360.4@48.79
EW=1643.2LB
EWCG=106.59"
Actual repeat offender.
Old 01-17-2011, 08:26 PM
eric.kallio eric.kallio is offline
Default Just weighed mine
Just weighed N518RV on Saturday:
1704 lbs total with all fairings, full interior, and soundproofing. Oink oink piggy!
Left main 663 lbs
Right Main 663 lbs
Nose 378 lbs.
CG 107.97
Eric Kallio
Old 04-04-2014, 05:07 PM
aturner's Avatar
aturner aturner is offline
Default adding to database
Weighed mine today, looked forward to this for a long time. 1563 lbs, which includes all fairings, interior accoutrements, and oil. No paint yet.
left main = 605
right main = 607.5
nose = 350.5
CG = 106.9" aft of datum
This airplane is about as stock as can be. No special weight savings measures, but not many extras either.
One surprise was that I took the time to measure the position of the wheels relative to the wing leading edge, and when comparing my numbers to the arms provided by Van's, mine are 3/4 - 1" different. These measurements are difficult to do accurately, but I believe my numbers are within an 1/8 or so. I know some folks just use the Van's provided arms, beware that the real arms for the gear on your plane may be different.
-Andy Turner
RV-10 N784JC
Old 04-04-2014, 09:00 PM
bill@fusion4.net's Avatar
bill@fusion4.net bill@fusion4.net is offline
Default Another Oink
363 nose
662 left
668 right
1692 total 108.56
I did the paint and primer, must have put too much in the tail
Good news is after 3.3 hr, no shimmy at high speeds, no heavy wings, and lands fine without any weight in the back solo.
Bill Thomasson
RV-10 - Flying - Phase II. 99.8% done... it's never really done!
http://sites.google.com/a/fusion4.net/rv10/
Suwanee, GA.
Old 04-04-2014, 09:49 PM
digidocs's Avatar
digidocs digidocs is offline
Andy,
Would you mind sharing what engine you have and a few details about your interior? Did you add any fabric panels, headliner, or carpet?
Thank you for sharing. It's great to get some real numbers about how differently equipped -10s weigh in.
David
Old 04-04-2014, 10:17 PM
aturner's Avatar
Dave, I have the usual IO-540 and two blade Hartzel. My interior is Abby's Flightline seats, my own carpet cut to fit the floors, and paint. Avionics are a two screen G3X system, and all the stuff that goes with that (which is light). One PC 925 battery. Some primer, but mostly unprimed. Pretty standard and basic. There are reports of lighter RV-10s which has me scratching my head, as I don't know how I would lose any significant weight from mine without going to a different prop or battery setup.
-Andy Turner
RV-10 N784JC
Old 04-04-2014, 10:19 PM
digidocs's Avatar
Thanks Andy,
That sounds like a great setup to me. Lots of useful load for sure!
Would love to see pictures if you have any.
David
Old 04-05-2014, 12:33 AM
dhmoose dhmoose is offline
Default Generalization
Something tells me that the numbers posted here are probably not a representative sample. In other words, more folks with smaller waist lines are more likely to report. Those carrying a few extra lbs might be a bit embarrassed
Maybe some of the bigger boys could post "the weight of their friends -10"
David Halmos
Flying - 420+ hours and counting!
Portland, OR
2018 - Dues paid
Old 04-05-2014, 04:16 AM
woxofswa woxofswa is offline
I am (hopefully) going to weigh in next week and I already know I'm going to be a "big kahuna".
I've got A/C, sound proofing, and overhead and center consoles. Oh well, that's ok. 5 minutes later to arrive comfortably is just fine with me. If I build a 12 or an 8 I will focus on sveltness, but I specifically chose the 10 for comfort more than performance.
Myron Nelson
Mesa, AZ
N24EV
RV-10 BPE, Dynon, Airflow systems A/C
First flight May 10, 2014
