Old 01-02-2011, 03:57 PM
Pat Stewart Pat Stewart is offline
Default Weight and Balance RV-10
Just curious if anyone would share their empty weight CG as well as actual weights at each location.
Pat
Old 01-02-2011, 04:05 PM
PatJBR PatJBR is offline
Smile
My C.G. was 106.92 Nose wheel 378 Right Main 637 and Left Main 638 Total Empty Weight was 1653 Flew great
Old 01-02-2011, 04:15 PM
tommylewis's Avatar
tommylewis tommylewis is offline
Default n143eb
n143eb has a cg of 106.09 with nose 378, right 598 and left 604 for a total of 1580.
Tom Lewis
RV7a N967BT 1670 hrs.
RV10 N143EB 760 hrs.
Granbury, Tx
http://bit.ly/2bnimsZ
Old 01-02-2011, 04:18 PM
My aircraft came out like this:
Right Main 613
Left Main 640
Nose 366
Total = 1619 for a CG of 107.58
I have no idea why the left main is so much heavier than the right main.
I will probably weigh it again next weekend and swap the left and right scales.
Pat
Old 01-02-2011, 05:49 PM
aerhed aerhed is offline
Maybe double check that you are level laterally & yeah, swap scales.
I'm waiting on scales now, so I'll post my weights in a week or so.
Actual repeat offender.
Old 01-02-2011, 09:14 PM
flyindoorman flyindoorman is offline
N710WH
Nose 385
Lt 625
Rt 628
CG 106.997
Randy
N433RV sold
RV10
Old 01-03-2011, 04:05 AM
RV10inOz's Avatar
RV10inOz RV10inOz is offline
773kg @ 2758mm
Old 01-03-2011, 01:37 PM
RONSIM's Avatar
RONSIM RONSIM is offline
Default On N9900M
Pat;
Left Main - 124.31 630lbs
Rt. Main -- 124.44 635lbs
Nose ----- 50.44 353lbs
1618lbs
Take Care,
Ron
Old 01-03-2011, 03:09 PM
rleffler's Avatar
rleffler rleffler is offline
Right Main 613
Left Main 640
Nose 366
Pat
Does the heavy wing have a servo and electronic trim?
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 01-03-2011, 03:30 PM
STARKEY'S RV-10 N210LM
WEIGHT AND BALANCE CALCULATOR
SAMPLE RV-10 Allowable CG Range - 107.84 through 116.24
Gross Weight Limits - 2,700 lbs. (Van's design numbers)
Determining empty CG
Weight Arm Moment CG
Right Wheel 636 124.44 79,144
Left Wheel 646 124.31 80,304
Nose Wheel 348 50.44 17,553
Total 1630 177,001 108.5897055
