Old 08-10-2018, 09:36 AM
rvdave rvdave is offline
Default Oxygen refill
I have a 12 cu ft tank from airox and have been having trouble getting it filled. Recently found an fbo who will fill it for $75, is this typical? None of the welding or medical supplies here will do it only exchange the steel tanks but they donít have aluminum tanks like mine. Anyone know of alternatives or is this what I should expect?
Dave Ford
Cadillac, Mi
Old 08-10-2018, 09:41 AM
Carl Froehlich's Avatar
Recent thread on this about filling your own tank: http://www.vansairforce.com/communit...d.php?t=162841
Old 08-10-2018, 11:07 AM
Tankerpilot75 Tankerpilot75 is offline
Contact a scuba shop.
Jim Harris, RV7A, 2nd owner, N523RM
IO-360, Hartzel CS prop, Older Aerotronics built panel Dual GRT Horizon WS, GRT EIS, Garmin 340, 335, Dual 430s, TruTrak 385 A/P with auto level, FlightBox hard wired to WS, Dynon D10A with internal battery (backup EFIS), 406 MHz ELT.
Retired - Living the dream - And going broke!
Old 08-10-2018, 11:22 AM
rcoleman-10 rcoleman-10 is offline
Default O2 Tank refilling
I am looking at installing O2 also in -10 and may follow a very similar design to the capability in the Glassair III as shown in the link beginning at minute 7 using the DeVilbiss ifill system.
Depending on how often you will be flying at altitude and require O2 will determine the cost benefit justification for the ifill.
https://youtu.be/xCoPQXH75JI
Ron
Old 08-10-2018, 12:28 PM
gfb gfb is offline
Find a scuba shop or local bulk gas vendor like praxair, airgas, etc. Expect to pay $25 tops for a fill, usually closer to $10-15 at a local scuba store.
RV-9A - started 01/2015, completed 07/19/2018
Old 08-10-2018, 03:09 PM
bruceh's Avatar
bruceh bruceh is offline
The local mechanic shop here fills mine for about $25.
Bruce Hill
RV-9A N5771H flown over 600 hours!
2019 VAF donator
EAA Tech Counselor
Old 08-10-2018, 04:37 PM
TurnsWrenches TurnsWrenches is offline
Go for the scuba shop, unless you can find a cascade setup at one of your local GA shops / clubs.
Old 08-10-2018, 04:52 PM
Thanks guys found a local scuba shop just got it filled $14.
Dave Ford
Cadillac, Mi
Old 08-11-2018, 04:06 AM
RV10inOz's Avatar
RV10inOz RV10inOz is offline
Scuba shops and Oxygen????? They normally do AIR only.
My buddy Deakin might have a suggestion https://www.avweb.com/news/pelican/182079-1.html
______________________________
David Brown
DYNON Authorised Dealer and Installer
The two best investments you can make, by any financial test, an EMS and APS!
Old 08-11-2018, 04:24 AM
Peter Costick Peter Costick is offline
David I imagine its oxygen from SCUBA shops supplying mixed gas or rebreather divers. Though I have to say when I was diving oxygen was taught to be poison at depth. Times change I guess.
Peter Costick
Melbourne Australia
RV7A Flying, VH-SVN
2019 Donation Made
