Old 08-10-2018, 07:25 AM
DJS DJS is offline
Cool Nose wheel shimmy
I have developed a nose wheel shimmy on landing rollout on my 600 hour rv10. Known issues? Suggestions for cause and fix? Thanks, Dave
Old 08-10-2018, 07:32 AM
Electrogunner Electrogunner is online now
Default Shimmy
Check the breakout force on the nose wheel. I think it should be around 25 lbs, but check that was from memory.
RV10 N620RV
IO540 C4B5
Whirlwind 375HRT
Garmin G900X
First Flight 2/14/2019
Old 08-10-2018, 07:38 AM
Carl Froehlich's Avatar
Yep - most of us have been there.
What I do:
- Get the replacement nose wheel axle and adjust the wheel bearing compression just like you do on the main gear. http://www.matcomfg.com/axleassembly...dv-3657-1.html
- Keep all tire pressures about 40 pounds.
- Balance all tires.
The point on doing all three tires is I found that a main gear bad or out of balance tire will cause nose wheel shimmy by itself.
If you are still on the orginal tires after 600 hours, recommend replacing them.
Old 08-10-2018, 07:39 AM
Bgill Bgill is offline
Default Shimmy
26# at the axle centerline for the breakout force.. doing my annual now - just tightened mine..
Byron
RV-10 40253 N253RV Flying
RV-14 140466 In build - Fuselage
Douglas, GA
Old 08-10-2018, 07:52 AM
N42AH's Avatar
N42AH N42AH is offline
Default Anti Splat Bearing Fix
Send your nose wheel off to Allen @ Anti Splat, and let them put in their sealed bearing, balance the rim and true the tire and your problem will magically disappear. That is unless something is bent or broken. And if you get the bent or broken part fixed...put a new tire on the nose wheel rim and send it off to them to do the above. Worked perfectly on all three ties for my 9A and on the nose wheel for my 10.
Steve Crimm
Gilbert, SC
Based - SC99
RV-10 N42AH
RV-9A N42AH - SOLD
Europa Monowheel XS N42EU - SOLD
BH-206B3 N42AH- SOLD
BH-206B3 N43AH - SOLD
Track N42AH/ N1FLY
Old 08-10-2018, 08:33 AM
Plummit's Avatar
Plummit Plummit is offline
Did you have to redrill the nose gear for the new tightened position?
-Marc
N814RV
2019 Donation Made
Old 08-10-2018, 08:40 AM
Mousse Mousse is offline
-Marc
I modified the nut as oppose to drill the gear tube. A lot easier.
Michel
Exempted but dues paid through 12/2019
RV-9 Sold
RV-10 Flying
Old 08-10-2018, 08:51 AM
Plummit's Avatar
Michel
Pardon me for being obtuse, but how did you "modify" the nut?
-Marc
N814RV
2019 Donation Made
Old 08-10-2018, 02:02 PM
ScottSchmidt's Avatar
ScottSchmidt ScottSchmidt is offline
Super Moderator
Make sure it is the nose wheel and not the mains.
The mains are known to shake around 25 mph when landing and people have said they have a nose wheel shimmy when a camera or the right shadow shows it is a main wheel.
When I first had a shimmy I thought it was my front wheel but a GoPro showed it was always the mains. The front never shook.
If it is the front, like others have said make sure the break out force is correct. You could even go one hole tighter and check it. Mine was a few pounds over the spec but loosens over time.
Scott Schmidt
Salt Lake City, UT
RV-10 N104XP (1280 Hours)
RV-12 N321UT (Sold)
Old 08-11-2018, 02:00 PM
-Marc
You make another notch between two existing ones. You only need one as there is no need for the cotter pin to reach both sides of the gear tube. Locking one side is enough. Hope this help.
Michel
RV-9 Sold
RV-10 Flying
