Old 08-09-2018, 09:47 PM
airguy's Avatar
airguy airguy is offline
Possible, but highly unlikely, that you've killed two of these units. I would strongly suspect a wiring issue.
Greg Niehues - PPSEL, IFR, Repairman Cert.
Garden City, TX VAF 2019 dues paid
N16GN flying 400 hrs and counting! Built an off-plan 9A with too much fuel and too much HP. Should drop dead any minute now.
Old 08-09-2018, 11:32 PM
One thing to look at is voltage. The red cube runs off 5 volts, not 12. Most EIS systems provide a FF power pin, but some expect you to tie into the instrument's general 5 volt bus.
I think for some time now they accept 5 - 30 volts.
Old 08-10-2018, 06:55 AM
lr172 lr172 is offline
Thanks for clarifying. The fact that they ran for a few hours had me thinking something was burning up.
N64LR
RV-10 in progress
Old 08-10-2018, 07:12 AM
DanH's Avatar
DanH DanH is offline
8 to 30. Is it hooked to a 5V instrument power source?
https://buy-ei.com/wp-content/upload...Info-Rev-F.pdf
Dan Horton
RV-8 SS
Barrett IO-390
Old 08-10-2018, 07:49 AM
PipeDreamer PipeDreamer is offline
Default Ground Check
Do a good ground connection check between the instrument chassis, Engine and fuselage. It could be some stray currents during the engine start, typically due to grounding issues.
Alex Babiy
Georgetown Ontario
RV-7A In progress.
Old 08-10-2018, 08:55 AM
woxofswa woxofswa is offline
I have mine mounted under the front of the engine between the Bendix and the spider. I secured it to the case on a short piece of bent spring steel to give a little vibration absorption and in a position where the output is canted upwards a bit per OEM recommendation. Itís been dead on accurate and trouble free for over 500 hours.
Myron Nelson
Mesa, AZ
N24EV
RV-10 BPE, Dynon, Airflow systems A/C
First flight May 10, 2014
Old 08-10-2018, 08:59 AM
Lynnb's Avatar
Lynnb Lynnb is offline
Myron, Do you have a picture of your install? Lynn
RV-10 in Process
Old 08-10-2018, 12:38 PM
JackinMichigan's Avatar
JackinMichigan JackinMichigan is offline
The second one failed before the first engine start.
Jack and Dave Groat, father and son
RV-10 N1861G
Build #41389, started Oct 2012
Current status: 1st Flight 11/10/17
Old 08-10-2018, 01:06 PM
9GT's Avatar
9GT 9GT is offline
Highly unlikely that a brand new transducer failed before first engine start. No one blew air through it did they? I had mine mounted in my -10 in the tunnel after the electric fuel pump also. It was very accurate there in the -10. I wrapped it in fire sleeve for a little heat protection just because I had some on hand. I would start troubleshooting the wiring. Ping it out, verify and triple verify the pin-outs. Check if a pin got folded over. Check the wiring shield braid for a stray strand, or even a pin that has a stray wire strand poking out. A stray wire strand can cause intermittent issues. My buddy had one in his magneto that only acted up when the mag got hot on his G3i set-up. We spent a lot of time trouble shooting that one!
David C.
Howell, MI
RV-9A: Under Construction.
RV-10: Completed 12/29/2013 SOLD 08/23/2016
"Donor Exempt" but donated through Dec. 2019
