Old 08-09-2018, 11:30 AM
RicoB RicoB is offline
Default Anyone has Spares AN3-56
Just checking around to see if anyone has 4 extras AN3-56 to sell, my master cylinder are not returning 100%, i already have install the spring kit, maybe i need to look into a heavier spring and i should switch the individual bolt for the long ones. Any other advice. There was a place selling those bolts from a surplus stock, AN3-56 S, they were $3 each but they are out. Maybe someone bought way more than needed and now it is just sitting there. thanks
Rico Burgos
RV9a at KWHP - Just out of Phase I
C-150 at KMOD
VAF Paid 2018
Old 08-09-2018, 04:24 PM
gfb gfb is offline
I'd be interested in the same.
RV-9A - started 01/2015, completed 07/19/2018
Old 08-09-2018, 04:51 PM
jibby212 jibby212 is offline
I have some, bought a pack of 28 or 30 for the same price 4 would have cost from Spruce. I gave some away but still have at least 12 I think. I will send them to you if I can find an easy cheap way to ship them.
Old 08-09-2018, 09:59 PM
terrye terrye is offline
Made mine from 3/16" stainless steel rod, cut to length, thread each end with a die and cutting oil and cross drill for a cotter pin. Installed using a washer on each end and a castle nut plus cotter pin on each end. Very inexpensive.
Terry Edwards
RV-9A (Fuselage)
2017/2018 VAF Contribution Sent
Old 08-09-2018, 10:38 PM
az_gila's Avatar
az_gila az_gila is offline
Smile
I did the basically same thing, but just followed the rudder pedal hinge construction on my Tiger.
Grumman simply used a 1/4" rod with a washer and cotter pin retaining it at both ends. Easier than threading.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 08-10-2018, 06:10 AM
WingsOnWheels WingsOnWheels is offline
I did the exact same, no need for threads in this application.
Colin P.
RV-6A #20603: Emp done,Wings done, Fuselage done, Electrical done, FWF about done, Canopy done, Fiberglass/Finishing in work. Getting very close!
PP SEL / A&P
N616CG (Reserved)
I donate every year on my B-Day (in Dec)
