Old 08-03-2018, 12:48 PM
rvanstory's Avatar
rvanstory rvanstory is offline
Default Front Tunnel Heat Ducts
I am on page 36-4 of RV-10 build. Putting in brake lines.
Last step is to rivet the heat duct onto tunnel walls. It says to use CS4-4 (counter sunk head) pop-rivet. Yet, no previous step shows to dimple or C/S the holes. If I use a LP4-3 (standard pop rivet) am I creating a problem down the road? I'm using Aerosport console and interior panels, and see now reason why a c/s rivet must be used.
Randy Vanstory
Building RV10
N783V - Reserved
Flying Mooney M20J
Emp Kit Completed, Tail Cone Attached, QB Wings delivered and starting Fiberglass Top.
Donation Happily Made 2019
Old 08-03-2018, 01:58 PM
majuro15's Avatar
majuro15 majuro15 is offline
I think I used a LP4-3 honestly. The Aerosport panels won't interfere with the rivets, as it's just the carpet panel that goes up against that area.
www.N1017H.com
Tim Huneycutt, Capt, NCANG
RV-10 Powered on!
N1017H Reserved
EAA #: 1106970
2019 VAF Dues Paid!
