Old 08-02-2018, 10:13 AM
MConner MConner is offline
Default Door release lever rattling
The thumb button on the inside door handles rattles on both doors. Is there an easy way to reduce the slop to eliminate rattling?
Old 08-02-2018, 12:19 PM
I am referring to the flat aluminum release lever that you push to release the handle to rotate. Maybe a grommet to shim the screw that acts as itís hinge?
Old 08-02-2018, 12:40 PM
rleffler's Avatar
rleffler rleffler is offline
I've not experienced that symptom in my RV-10 or any of the ones I've flown.
The good news is that whatever is causing the issue, it's consistent in both doors. It should be able to be tracked down. My suspicion is that there is some minor deviation from the plan and something isn't fitting quite right. But that's purely speculation on my part.
You may want to grab another local builder to review the installation. Usually things are more apparent to another set of eyes.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 08-02-2018, 01:04 PM
az_gila's Avatar
az_gila az_gila is offline
Smile
Quick guess.
The hinge end of the flat lever that has the 'push button' on one end is rounded to fit into a hole in the internal push rod.
If it was over rounded during construction it certainly could rattle. Figure 3 on plans 45-10.
The hole for the central hinge bolt of the same part could also be oversize - Figure 4 on the same plans sheet.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 08-02-2018, 02:18 PM
Is the spring that holds the outside button out in place?
Old 08-02-2018, 06:07 PM
Originally Posted by az_gila View Post
Quick guess.
I think you got it Gil, maybe I will try some shimming.
