Old 08-01-2018, 01:11 PM
Bill Boyd's Avatar
Default RV 10 question
My kit came without a fair amount of the finish kit components. One item I need soon is the elastomers that are sandwiched in the nose gear mount, J-11968-14.
The plans seem to depict 4 units in a stack with some associated shims/washers. The mothership lists them as
GEAR ELASTOMER -10
EA J-11968-14
$138.00
As packaged, do I need one of these, or four?
On a somewhat related note, Van's doesn't seem to sell a right-sided wire cover plate equivalent to the F-10110-L. Can this part be made to work on the right side if I decide I want two?
Bill Boyd
Hop-Along Aerodrome (12VA)
Old 08-01-2018, 01:36 PM
lr172 lr172 is offline
I believe four of them were shipped with my kit, but will need to double check. The ladies in the kit dept can look up the BOM to confirm.
I also wanted a wire cover for the right. They are assymetrical so the left won't work. Please let me know if you figure out an option for this.
N64LR
RV-10 in progress
Old 08-01-2018, 01:54 PM
rleffler's Avatar
rleffler rleffler is offline
GEAR ELASTOMER -10
EA J-11968-14
$138.00
It's probably worth a call or email to confirm the quantity in that sku. You'll need four. Also, check out the service bulletin for some extra parts that you may not have depending on the age of your motor mount.
I can't answer your wire cover question. I attempted to look up that number in my copy of the plans, but couldn't find it. The wire cover that I assumed your were talking about had a different number. It's amazing how quickly you forgot all that stuff you had memorized while building after you are flying. But that's probably a good thing..........
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 08-01-2018, 02:26 PM
az_gila's Avatar
az_gila az_gila is offline
Smile
If you are using the Aerosport interior kit, or something similar, you won't need a wire cover on either side. The trim panel covers up the wiring.
The wiring cover is shown on OP37-6.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 08-01-2018, 05:19 PM
Flandy10 Flandy10 is offline
As Bob said, you won’t need them if you use an aftermarket front interior panel. Also, it wouldn’t be the first time I’ve called Vans and had the webmaster fix their online parts for sale lists.
If you really want them, I believe mine are laying on a shelf in the hangar.
Scott Flandermeyer
Rv-10 TDI #40816
Fayettevile, GA
2018 VAF Donation complete
Old 08-01-2018, 05:50 PM
When I looked, that page only shows the left and does not mention a cover for the right.
N64LR
RV-10 in progress
Old 08-01-2018, 06:21 PM
az_gila's Avatar
Smile
Yes, I was answering Bob's comment that he couldn't find it on the plans...
But buy the Aerosport interior, it will look nicer and cover a lot of wiring in all of the side panels. Vans wiring cover was designed for the pretty minimalist electrical system shown in OP-37.
Gil Alexander
Old 08-01-2018, 06:29 PM
Bill Boyd's Avatar
I think I will buy an aftermarket interior eventually, Gil. But not just yet. My plan is to get this thing flying in a few years in a minimalist configuration and add-to-taste from there.
Bill Boyd
Old 08-01-2018, 07:59 PM
az_gila's Avatar
Smile Side panels only
Looking at the Aerosport parts I have it seems that just putting in only the side panels at first may actually be less construction time. They seem to fit pretty well straight out of the box.
You can put them in plain now and cover/paint/dude-em-up later...
Gil Alexander
Old 08-01-2018, 08:42 PM
DRMA DRMA is offline
I also wanted the right side cover, so called Van's. They don't make one for the right side.
So I ordered some thin aluminum sheet from ACS and made my own. Measured the left side cover provided with my kit, and then drew the mirror image with all the dimensions. Transferred these dimensions to the sheet aluminum and cut it out. Then bent to the dimensions using the edge of my workbench for the long bends and sheet metal pliers for the smaller bends. The resulting cover may not be perfect, but it fits well and isn't noticeable as being different from the left cover. Wasn't as difficult to fabricate as I thought it would be.
Dave Macdonald
RV-10 Finishing Kit & FWF in-progress
2019 VAF Dues Paid
