Go Back   VAF Forums > RV Firewall Forward Section > Traditional Aircraft Engines
Old 09-19-2018, 03:28 PM
TShort TShort is offline
Default Help needed troubleshooting rough running O-320
I'm hoping for some wisdom / assistance in helping a friend troubleshoot a rough running engine in his purchased RV-9.
Background: RV-9, carb'd lycoming o-320, dual mags, pretty much basic setup as per vans.
Jim bought the airplane earlier this year, it was pretty new with phase I flown off. Has about ~75 hours now. Aside from some warmer CHTs, the engine had been running fine.
Early Aug, he and a friend flew to a nearby airport for fuel. On return, (in the dark!) the engine began running rough. Runs rough at higher power, seems to smooth out if the throttle is pulled back.
I am going to link to engine data from 2 flights:
First, before any issues arose and the engine was running well (this was takeoffs and landings at our local airport):
https://savvyanalysis.com/flight/271...4-e3f9159664d2
The flight where issues arose:
https://savvyanalysis.com/flight/271...4-0a621ccead39
I am going to share the link with Jim so he can register / login and help answer any other questions. Not sure he is on VAF yet.
Thanks in advance for any thoughts / suggestions
Thomas Short
KUMP - Indianapolis, IN
RV-10 N410TS bought / flying
RV-8 wings / fuse in progress ... still
1948 Cessna 170 N3949V
Old 09-19-2018, 03:32 PM
Here are screenshots of the above flights (clicking the savvy links in the above posts takes you to the actual data, where additional parameters can be added / compared):
Normal flight:
Rough engine:
Thomas Short
Old 09-20-2018, 12:44 AM
Captain Avgas Captain Avgas is offline
Default Savvy analysis
Tell your mate Jim to dust the cobwebs out of his wallet and get Savvy Analysis to inspect the data. They are the absolute experts at this. Their opinion would undoubtedly be more valuable than any free opinions on this forum.
Regards
Bob Barrow
RV7A
Old 09-20-2018, 06:41 AM
krw5927 krw5927 is offline
Those are some seriously high CHTs.
Kurt W.
RV9A
FLYING!!!
Old 09-20-2018, 07:27 AM
MarkW's Avatar
MarkW MarkW is offline
As Kurt says, kinda high on the CHT's.
It would be very helpful to know at what time it started running rough.
There is a large FF drop at 25:52 with a small RPM change.
If that is where the problem started it sure looks like fuel flow.
However EGT #4 started wondering of about 23:30.
RV9 - N14MW - Flying
G3X - ECI Titan I0-320
Catto three blade prop
http://www.mykitlog.com/MarkW
Old 09-20-2018, 09:14 AM
Haha. We talked about that.
There is tons of great knowledge on this board ... I was hoping for some insight or thoughts on troubleshooting.
The front page exposure definitely helps - thanks Doug!
Thomas Short
Old 09-20-2018, 09:15 AM
Agree about the CHTs
We've talked about that and are looking at the issue.
Baffles etc look good.
Anecdotally, he's been told "this is a common problem with the RV-9 in climb" - any truth to that?
Thomas Short
Old 09-20-2018, 09:27 AM
Tumper's Avatar
Tumper Tumper is offline
Looks a lot like my EKG...
Dean Eiland
Aubrey, TX
Former Vice President EAA Chapter 1246
RV-9 (yes) N369RV
Mattituck IO-360, C/S Whirl Wind Prop, GRT, Digiflight II, Garmin SL30 & GTX 330 and Hotel Whisky Aux tanks, Bla Bla Bla
Flying
Old 09-20-2018, 09:33 AM
jpowell13 jpowell13 is offline
Default Loose Carb?
This may be totally off (I'm no expert) but its easy to check. Have the nuts that secure your carb loosened up? John
Old 09-20-2018, 09:45 AM
Shark's Avatar
Shark Shark is offline
I had a similar experience, the carburetor bolts backed off that held the carb together which intern allowed the carb to split just enough to leak gas when the fuel pump was on and I'm assuming suck air when it wasn't. Anyway she ran a bit "rough" (Scary) all fixed and safety wired
Donaven
Lake Elmo MN.
RV9A
