Old 09-15-2018, 07:33 PM
ILikePike ILikePike is offline
Default Hot Start Solutions
I have an RV-8 with a YIO-360-M1B 200hrs TT equipped with Slick 4373 (impulse) on left and 4370 on right. It has been very challenging to hot start this summer. I recently purchased a Slick Start module to install on the left (impulse) mag.
I have a Dynon SV-EMS-220 picking up the tach signal from the key switch left and right p-leads through 30Kohm resistors. The Slick Start manual has a warning statement "CAUTION: ELECTRONIC TACHOMETERS UTILIZING A MAGNETO PICKUP ARE NOT COMPATIBLE WITH SlickSTART"'. THE TACHOMETER SENSOR SHOULD BE RELOCATED TO THE RIGHT HAND MAGNETO." Is the Slick Start going to cause a issue with the Dynon SV-EMS-220 or will the 30Kohm resistors protect the Dynon from the boost?
Is anyone running dual impulse mags to aid in hot starts? My Bonanza (IO-520) has dual impulse mags Slick 6310s. It requires good hot start technique but will hot start most of the time on the first try. If not on the first try, the mixture/throttle dance will work. Ironically, I checked today and discovered that the right mag has been grounding (for the last 10 years) when the key switch is engaged. I guess the key switch jumper was never removed when the engine was replaced in 2008. It was originally equipped with a shower of sparks. Can someone confirm that when running dual impulse mags the switch jumper should be removed so that both impulse mags will operate during the start.
Jeff Green
2016 RV-8 #82985
1968 E33C Aerobatic Bonanza
Pleased to donate Dec 2018
Old 09-17-2018, 07:35 PM
So, is anyone using a Champion Slickstart and Dynon tach pickup on the same P-lead?
Jeff Green
2016 RV-8 #82985
Old 09-18-2018, 05:54 AM
Mark33's Avatar
Mark33 Mark33 is offline
Default Mag problem VS. hot fuel/vapor lock
So are you sure you’re having a mag problem and not a hot fuel/vapor lock problem?
Old 09-18-2018, 06:48 AM
Electrogunner Electrogunner is offline
Default Slick start IO 540
I'm running a slick start on my NON impulse coupled left mag. My tach pick up is on my right mag. I have the right P lead run through a relay that closes/grounds when the start button is activated. Worked perfectly so far but I'm still in testing stages so haven't dealt with hot starts yet. I believe this is a very common setup.
RV10 N620RV
IO540 C4B5
Whirlwind 375HRT
Garmin G900X
First Flight 2/14/2019
Old 09-18-2018, 09:25 AM
jwilbur jwilbur is offline
I have this setup. But I have both p-leads wired into the Dynon so when the one is grounded during start Dynon automatically picks up the other. I have not had any issues with the Dynon but I increased to 100 kOhm because on the IO-540 the tach reading was too jumpy during takeoff.
-Joe Wilbur (N520LW)
Phase II - 11/2017
First flight - 8/2017
RV-10 Build Log
Old 09-18-2018, 11:31 AM
pvalovich pvalovich is offline
Default Hot Starts in the Desert
FWIW - may not apply 100% but it always works for me at IYK where the temp is over 100 degrees every summer afternoon. Use this after restarting after an engine shutdown; fist start of the day unaffected by temps.
RV-8A IO-360; I mag, 1 Lightspeed
Do not prime
Ignitions - Both on
Prop - Full forward
Throttle - full open
Mixture - Idle Cut Off
Starter - engaged
Mixture - Forward as soon as engine catches
Throttle - idle
Electric Boost - On if fuel pressure drops, then off
Old 09-18-2018, 12:46 PM
rdrcrmatt rdrcrmatt is offline
I've just been leaving the oil door open to help vent the heat. Hot starts are much easier.
Matt
CFI / RV-10
Old 09-20-2018, 05:51 AM
Thanks for all the advice. In working the hot start issue I have replaced all plugs after finding most with high resistance and checked timing on both mags. I already use the oil door trick when doing a quick turn. I think the tightly cowled engine is just temperamental on hot days. Planning to install SlickStart this weekend and will report results.
Jeff Green
2016 RV-8 #82985
Old 09-20-2018, 06:58 AM
Default OK.
We are set-up much the same way as you are. An old trick we learned while running IO-470's in south TEXAS, that is not in the books that we have found works with the IO-360 with Mags, after a quick turn around. Open the oil door while you fuel, wash hands and take a nature break after fueling, close oil door, set throttle to just above idle so the engine will stay running at 900-1200 RPM's once it catches, mixture full rich, take the key in one hand and the boost pump switch in the other hand, start turning and then just a half second later flip the bust pump on. Once the engine catches flip the bust pump off and chase the throttle to keep the engine running. You will have to let the engine slowly clear the vaper out of the spider lines and settle the engine idle down to smooth again, witch may take a half minute or so. Just something we found while in the hot sun a few times to get us going again.
Hope it helps. Yours, R.E.A. III #80888
Old 09-20-2018, 07:17 AM
rbibb's Avatar
rbibb rbibb is offline
IN a Mooney I used own (had angle valve IO-360, tight cowl, cooling not dissimilar from an RV) I used this technique for hot starts.
1) Throttle Full open
2) Mixture lean to cutoff
3)couple shots of prime
Engage starter.
When it fires push mixture in while pulling throttle out at the same time.
Obviously this requires some hand dancing but worked consistently.
YMMV
Richard Bibb
RV-4 N144KT
Fredericksburg, VA
KEZF
