Go Back   VAF Forums > RV Firewall Forward Section > Traditional Aircraft Engines
Old 07-14-2018, 11:47 PM
WingnutWick's Avatar
WingnutWick WingnutWick is offline
Default Changing the engine driven fuel pump - advice?
Hello all,
My engine driven pump is not hacking it at full throttle/full rich settings, often plummeting to 0-1 psi with increasing EGTs as it goes below 1PSI (carberauted). So Iím going to try swapping out the engine driven pump with a new one. Hopefully this fixes the problem.
Iíve never messed with the pump, is there any difficulties swapping these out or is it just plug and play? What are the procedures? Anything specific with gaskets, gears, etc?
Thanks all!!
Wingnut
-Wingnut
Rhino driver by trade
RV-8 O-360
Old 07-15-2018, 12:02 AM
Plummit's Avatar
Plummit Plummit is offline
I can tell you that at least on the IO-540, it can be interesting to change the pump. You have to hold the pushrod up then install the pump before it drops too low. Took us a while but we also had the shroud with blast tube.
-Marc
N814RV
2018 Donation made!
Old 07-15-2018, 03:40 AM
Robin8er Robin8er is offline
Its pretty easy. I had to install mine. There is just a gear with a lobe on it that presses the plunger down to push the lever on the fuel pump. That's how the system works.
If the plunger wont go up it's because the cam lobe on the gear is in just the right spot to push the lever down. If this happens, rotate the crank shaft one turn and that should be enough to move the gear out of the way. Its a pretty east job. As long as you don't force anything I don't see how you can screw it up.
RV-8
N695RA Reserved
Emp and Wings done, working on Fuselage.
Born to fly, forced to work
Old 07-15-2018, 06:55 AM
DanH's Avatar
DanH DanH is offline
Tie a long length of string, dental floss, fishing line, or similar into a big loop. Rotate the crank until the pump plunger is as high as it will go in the accessory case pump cavity. Loop the string around the plunger. Drape the other end of the loop over a handy motor mount tube and hang a big weight on it. Push the plunger up and the side force should make it stay. If not, add more weight.
Insert the pump, install the two screws, and run 'em in until there is just a small gap between the pump and the accessory case. Cut the string loop, pull it out, finish tightening the pump screws. Done.
Dan Horton
RV-8 SS
Barrett IO-390
Old 07-15-2018, 07:04 AM
catmandu's Avatar
catmandu catmandu is offline
The above method is good advice, but see if the plunger will stay in place all by itself long enough to get the pump in place. Mine did when I changed it this winter. There are lots of scary threads on how hard this swap can be, I thought it was pretty straightforward, even for a feeble minded old legacy driver.
Mike C.
Maryland's Eastern Shore
stuck in 1/5th of an Arrow, my partners won't let me go
RV-6A bought flying
thinkn9a thinkn9a is offline
Default Search on ď replacing engine driven fuel pumpĒ
There are some warnings -
Fatal crash due to improper install, with plunger not properly aligned.....
And tips/ reminder
- position prop so that plunger is at top,position...... remember safety with prop
- use lace cord to hold plunger up
- use a wobble (some call ball) hex drive
Read through post started by Alex Peterson...2/11/2007...... and Iím sure there are others with good info
Wallace & Marietta Goodloe
9A -QB
N211LV
Phase 2 has started!
Thanksgiving time, is dues time for us
Old 07-15-2018, 07:05 AM
seems you could trouble shoot the problem by turning on the electric fuel pump when the problem occurs. at times we end up chassing problems before diagnossing the problem.
dan, that is some good diagram work there.
TURBO YES =VAF= Payed Jan2018
Old 07-15-2018, 04:11 PM
Yes, I do this every time the PSIs drop. The electric pump keeps the PSIs nominal >4PSI.
-Wingnut
RV-8 O-360
Old 07-15-2018, 09:38 PM
Default Thanks!
Dan,
Thanks! What torque on the screws? Also, any alignment to be done or is that all there is to it? Ref. - "Fatal crash due to improper install, with plunger not properly aligned....." would like to avoid that haha.
Do these pumps come with new gaskets? What do I seal the gaskets with?
Thank you!
Wingnut
-Wingnut
RV-8 O-360
Old 07-15-2018, 09:58 PM
tturner tturner is offline
Be sure the pump is your problem. I had an RV4 with a o-320 that 0n two occasions I had the engine fuel pump pressure drop below 1 psi at take off power. Both times it was due to trash in the in line fuel filter. Cleaned the filter and the pressure returned to normal.
Tommy Turner
Fayetteville GA
RV-4 sold
RV-6 flying
RV-8 Flying
