Old 01-22-2018, 12:54 PM
psalys psalys is offline
Default RV-12 to sit in
Anyone in the Eugene, Oregon area have an RV-12 I could come sit in? I’m 6’4” tall and am trying to determine if I need to order a lower seat cushion or if removing the ‘wedge’ will be adequate.
Call or text 541-2eight5-771four.
Patrick
Waiting on Avionics Kit (since Dec 6th!!!)
Powerplant complete
Finishing complete
Fuselage complete
Wings complete
Emp and Tail Cone complete
Dues paid
Old 01-22-2018, 01:00 PM
Take a little trip up to Vans??
Old 01-22-2018, 01:36 PM
rv9builder rv9builder is offline
Lane Community College Aviation Academy has an RV-12. Synergy Air, where they make the ELSA RV-12s is also in Eugene.
RV-12iS Fuselage
RV-9A Project: Sold
VAF donation made for 2019
Old 01-22-2018, 03:24 PM
Good idea. I'll try that if no one else offers.
Patrick
Powerplant complete
Finishing complete
Fuselage complete
Wings complete
Dues paid
Old 01-22-2018, 09:40 PM
Dvalcik's Avatar
Dvalcik Dvalcik is offline
Patrick
I’m 6’4 and cut the foam wedge in half and stuffed it back in the case
David
EAA 1434 KBST
Belfast, ME
david@rv12pilot.com
2019 VAF Supporter
RV12 #568 EAB
* Started 9/30/2011
* 1st flight 8/30/12
http://www.rv12pilot.com
Old 01-23-2018, 01:47 AM
Gagarin737's Avatar
Gagarin737 Gagarin737 is offline
I'm also 6'4". I don't use the wedge and have 4 fingers space between my head and the canopy. A thing to consider is that when you don't use the wedge there is a gap between the seat and backseat. Abby can make a longer backseat to avoid the gap and with that the lumbar support is also somewhat lower.
PH-BZT
MyKitlog
Picasa pictures
Old 01-28-2018, 08:52 AM
Thanks all for the comments. I went to Synergy Air and fortunately they had a 12 that was almost done I could sit it. Turns out I am much too tall for the regular seat cushions. Ryan and I took the seat cushions out and taxied out to the run-up area at KEUG and did a full power run-up. Awesome! I had about 3 inches of room above my headset with no seat cushion.
I will definitely ask Abby for lower seat cushions.
Thanks Ryan and Synergy Air.
Patrick
Powerplant complete
Finishing complete
Fuselage complete
Wings complete
Dues paid
Old 01-28-2018, 04:38 PM
RV12JT RV12JT is offline
Patrick
Were you sitting the New iS?
Old 01-28-2018, 08:20 PM
rjtjrt rjtjrt is offline
Patrick
Just a thought, but if headroom is the issue, and the headset hitting canopy, then if you use a Halo or Clarity Aloft headset that will give you a lot more space to work with.
Probably you are already well aware of this.
You still need some gap above head as RV-12 can/is bumpy in any turbulence.
John
