Old 02-22-2018, 06:59 PM
Tomcat RV4 Tomcat RV4 is offline
Use aftermarket conical filter on inlet ,very little chance of being totally covered, +
they can be cleaned and reused ! Tom
Tomcat RV4
dues paid and worth every penny
Life is uncertain -Eat desert first !
U F O Member since Dec 2017
Old 10-04-2018, 05:32 AM
SgtZim SgtZim is offline
Default Is there an upgrade available?
Now I have to make the call as I'm doing the firewall forward stuff. I was leaning to going ahead and installing the Van's bypass (IO with snorkel), BUT:
A. The door and the seat fit poorly. I can sand the door and get it flatter, but the seat/flange is warped and twisted in the stamping process. I'm not sure I can grind it flat enough to seal well, especially after dimpling the holes on the flange. I worked hard to get a good fit and seal on the filter, don't want to add a permanent leak in the system.
B. Speaking of the flange - The instructions have you machine countersink the snorkel in 5 places to mate with the flange dimples and you pop rivet into those - makes a very marginal attachment as you have machined away most of the fiberglass that the pop rivets are gripping (crushing and pushing away as they set).
C. Still some potential for hardware to go down the pipe.
Question for the experienced mechanics and industry wonks - how much leakage past the filter is ok? The snorkel install says I should drill a drain hole at the low point of the snorkel - also I'm not doing that. I have a sniffle valve on the bottom of the manifold to drain moisture and stuff.
So, I'm back to not installing this system at this time. Has anyone made a better mousetrap?
RV-8 slow build
IO360-M1B Sensenich fixed pitch
Garmin G3X
GTN 625
GNC 255
GTR 20
GTX 45R
G5 x 2
Facebook "log" https://www.facebook.com/BZsRVproject/
Old 10-04-2018, 07:04 AM
Dan Langhout's Avatar
Dan Langhout Dan Langhout is offline
Default Better Mousetrap
HERE is a link to a thread I posted several years ago. Opens AND closes from the cockpit, nothing to ingest into the engine. 4 years and 365 hours of trouble free operation - well . . . . . I haven't had to ACTUALLY use it thank goodness, but it still functions properly and hasn't failed
Dan Langhout
2019 =VAF= Dues PAID . . . . .
RV-7 N528DP slow build
First Flight July 26th, 2014
437 hours and counting . . . .
Now based at Moontown (3M5)
Old 10-04-2018, 09:54 AM
Thanks Dan, that looks really nice. I'm filing your link for future reference - one of those nice add-ons I can do once the plane is flying.
RV-8 slow build
Garmin G3X
GTN 625
GNC 255
GTR 20
GTX 45R
G5 x 2
Old 10-04-2018, 10:25 AM
grubbat's Avatar
grubbat grubbat is offline
Default Alternate air door
I had an alternate air door come off a certified plane and get lodged ahead of fuel servo. It was the spring loaded type connected to a push/pull cable. If i were designing one, I'd probably make it from a push/pull cable that if failed, couldn't be injected into motor. I don't prefer the magnet or spring loaded type.
Craig
RV-3 Sold
RV-4 Sold
RV-6a Sold
RV-9 IO-360 CS, Built and Flying
Comanche 260 - poor mans RV-10
Old 10-04-2018, 06:49 PM
rzbill's Avatar
rzbill rzbill is offline
There is an old racing adage about winners and speed hardware - "Its not what you put in, it's HOW you put it in".
I think it could apply to the alternate air/filter bypass hardware.
I have the horizontal injected snorkel rotating round door type.
I used the Vans hardware but I did not follow their directions much.
Happy at 750hrs and no indications of change anytime soon.
And dispite the Vans note that the door cannot be reclosed/reset via the cable. Mine does easily.
Here's the first of 3 pages on the subject.
http://websites.expercraft.com/rzbil...y&log_id=63249
I did not talk about it in the blog but I did spend time massaging the parts to make sure they were both FLAT. Not kinda flat, FLAT.
Bill Pendergrass
ME/AE '82
RV-7A: Flying since April 15, 2012. 750hrs
YIO-360-M1B, mags, CS, GRT EX and WS H1s & A/P, Navworx
Unpainted, polished....kinda'
My RV Construction Page
