coolant leak
edward7048
I have a slight coolant leak that I can not find where it is leaking, does
know of a coolant pressure tester that will work with the Rotax coolant
system?
I don't know about a tester, but I had a tough time getting my hoses tight enough to not leak, especially from the water pump and into and out of the radiator.
The only place that I see coolant is in the bottom of the cowling
and the hanger floor under the back of the bottom cowl.
I'm digging back here, but as I recall there is a weep hole on the bottom of the water pump that monitors the water pump seal. Might want to check and see if it's wet.
Rich
My Rotax 912 ULS will loose a little coolant from various places while sitting in a hangar where temperatures are dropping below freezing. A chat with Lockwood indicates this is not unusual.
The water pump has a ceramic seall and a weep hole on the bottom of the pump. During times of cold temps the different contraction rates between different metals and seals can cause a very small leak. This is usually limited to a tablespoon or so of coolant. This can be quite normal and can be on and off. So long as you don't have a large puddle on the ground I wouldn't worry.
too funny!
...I started reading this, and chuckled....." there's no coolant in a Lycoming.....'cept fer that AIR flowing everywhere....":rolleyes:
...and then went back to wiping OIL from my lower cowling! :D
( as they say, no free lunch)
Leaking radiator hose.
I had a problem with the hose from the water pump to the radiator leaking. Went thru several of the worm clamps before finding some heavy duty clamps at NAPA that did the job.
We always called these Cold Water leaks and Silicone coolant hose seems to be the most difficult to get to quit leaking. The wider HD worm clamps will usually solve the problem.
Spring Clamps recommended
.... Went thru several of the worm clamps before finding some heavy duty clamps at NAPA that did the job.
I just got back from iRMT class at Lockwood. We discussed hose clamps and we were told that Rotax has a good reason for using the spring clamps. The spring clamps allow for expansion without deforming the hoses. Worm clamps, on the other hand, tend to deform the hoses, especially because most people over tighten clamps.
It's easy to get in a vicious cycle of tightening the clamps to stop the leak - deforming the hose by over tightening and having the leak re-appear then tightening some more, etc.
BTW. We also used a cable operated hose clamp plier. The make installation/removal of spring clamps super easy and you don't have to worry about damaging the clamp.You can find them at auto parts stores for under $25.
coolant leak at overflow bottle
I had a similar problem. On pre-flight, found coolant on hangar floor below cowling, under passenger floor mats, and coolant spots all around firewall. Coolant overflow bottle almost empty. Bottle OK, cap breather hole OK. Diagnosis: leakage during previous day's flight at slip-on hose connection to bottle. Hose elasticity probably compromised, especially at bottle connection tube 'bulb'. I cut off 3/4" at hose end, reattached, but added hose clamp. Hose rubber at end of useful life? TT @ 230hours, Engine installed June, 2010.
Hose to overflow bottle failed today
After a few hours of Young Eagle flights today, and about to put my -12 back in the hanger, notice a puddle forming of Dexcool coolant on the taxiway. The hose attached to the reservoir for the coolant had failed. Small crack in the rubber and the hose apparently fell off. Lost about 2/3 of the coolant in the overflow bottle but coolant level in the system itself unaffected. Rest of hose looked fine - cut off about 1/2" and reinstalled. Probably discovered it just after it happened as a lot of the coolant was still dripping through the engine area.
After doing my condition inspection and hose replacement, I refilled my cooling system with fresh Dexcool. Filled the reservoir up just a hair below the MAX line. On the first test flight I thought I caught a whiff of coolant while on the ground, but everything seemed fine. After the engine cooled down, I noticed the coolant level was down about 3/4 inch. Looked for a leak, found nothing, topped it back up. Same thing on the next flight. I finally figured out maybe the MAX line was a little above the MAX for my plane. So, stopped topping it off and it hasn't lost any since then.
Kind of like putting 8 quarts of oil in a Lycoming. Dipstick says it's full, but the engine will usually just blow a quart overboard and find its own "full".
Exactly!!
Hose materials creep under load, and ordinary hose clamps have a constant diameter, regardless of the force. Once the temp goes up the expansion of the aluminum tube, and accelerated creep of the hose material, the fixed diameter of the typical clamp is no longer "tight" when it cools back down. The spring-type hose clamp is the only solution for this. This also applies to turbocharger hoses, so you will notice these on heavy duty applications. These will solve the cycle of hose leaks.
For the finding the leaks ( BMW is a super PITA about leaks) I use a tee in a small hose (1/4" ID), and with a cheap air pressure regulator, gage and valve, use this to pressurize the system. Just be sure not to exceed the cap rating. Then I got some dye from O'Reilly's for the coolant and use a black light to locate the leak source. It will stand out like a sore thumb. ZEP orange cleaner will remove the dye for continued monitoring. You can use a small pressure tank as this won't take much air supply. Heck, your garden sprayer will generate enough pressure. ($7)
Coolant hoses can ooze or leak when exposed to heating and cooling cycles and especially in cold weather it may shrink a tad and the clamps being a different material don't keep up. The rubber will compress from a clamp over about 25 hrs. During the Rotax first 25 hr. warranty inspection or after a hose change these clamps should all have a wrench put on them to check for tightness.
As far as a wormdrive clamp I personally don't like the serrated type with the openings. These can be over tightened and slip and they cut into the hose.
Many prefer the Wurth wormdrive style clamp. It has raised ridges and will not cut into the hose and usually won't slip the notches like a serrated open grooved type will unless you severely over tighten them. It's a better choice over the garden hose variety type.
In answer to an old question in this subject, the radiator pressure tester from Harbor Freight Aviation Supply has an adapter that works on the Rotax.
I also found the spring loaded worm clamps work great at the radiator hoses. It helps that they completely wrap around the hose under the worm screw.
Coolant change
How often should the coolant liquid be changed? I'm sure it's written someplace, but I can't find it. Thanks.
The RV-12 maintenance manual refers you to the Rotax maintenance manual. The Rotax line maintenance manual says only that it must be replaced when overhauling the engine, or when the manufacturer says to replace it. They don't say whether they are referring to the coolant manufacturer, or the airplane manufacturer. So... apparently, check with the coolant manufacturer.
I figure the cooling system has to be completely drained to replace the hoses every five years, so that's when it gets new coolant. I think the jug of Dex-Cool I bought also says 5 years/150K miles.
Edit: Of course this assumes Dex-Cool coolant, there are other types. I know nothing about them. Check your coolant for more information about its service life, I guess.
Upon a recent pre-flight check, I found my overflow tank tube cracked in the same manner as in your pic.
I did the same, removed, cut 3/4" off, and reinstalled. This IMO should hopefully hold until my 5 year full hose changeout in 2 years.
I have the same problem with the overflow bottle hose keeps leaking and splitting.
It seems the hose is too small in diameter for the application.
I assume the problem is a result of making a standard hose fit a metric size nipple.
Has anybody found a better replacement hose than the supplied 3/16" hose?
Would like to have that fixed before first flight.
Thanks John for your quick reply, and your homework on the subject.
I'm going to look for a bigger hose.
