Hi everybody,
I'm flying a RV7-A with a IO360 A1A since 5 months. Engine has 1500 hours and has been top overhauled before i bought it. It is equipped with a governor and half christen system (oil separator).
I have chrome cylinders and everything above 6-6.5 quarts spits out to the belly.
So i recently made some flights to measure my oil consumption and define what was the "good" oil level for my engine.
During cross-country flight, with 7-8 quarts, i can see a steady constant oil pressure (75 psi). oil consumption is about 0.4qt per hour.
Here is a snapshot of EFIS data for a 7qts cross country flight :
The issue appears when oil level is about 5-5.5 quarts. At this level, Oil pressure drops to 60 psi in average and i can see oil pressure fluctuation during all flight. At the same time, oil consumption is ok (0.1qt/h)
At 5qts :
At 4.5 quarts, oil pressure is 50-55psi in average and can drop to critical level in steady nose down or during bumpy weather. I stopped tests here.
2 things i'm bugged with :
- oil pressure seems to be dependent of oil level, that is very strange to me
- i suspect oil fluctuation means pump sucks air because of "low" oil level. But 6 qts seem not to considered as low level, based on experience of other pilots.
The solution is certainly to fly above 6 qts but i'm keen to understand the root cause of this issue before adding oil.
If anybody has encountered the same situation, I would be happy to hear about it.
At 5qts :
